Silly question: destroyed a capacitor by solder iron?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Well, it's true that eventually if you heat the pins of an electrolytic capacitor with a solder iron, the bung will melt and destroy the capacitor, but have anyone actually destroyed a capacitor by overheating a capacitor such that the electrolyte seeps out? Is it possible?
    Any solder/desolder mishap stories to share?
    • 31050
    Re: Silly question: destroyed a capacitor by solder iron?
    done that while trying to desolder some from modern pcb's that have very-high melt point solder.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Interesting, thought the wires were somewhat "resistive" (takes a while to heat up one end and have the heat conduct to the other) that it'd take quite a bit to cause the electrolyte to boil?
        • 31050
        the wires are copper, better than aluminium and second only to silver on the thermal conduction scale!
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Actually thought most caps' leads were STEEL?
          Check a magnet!
            • 31050
            that's probably tin plating, although they used to be aluminium.
            (still with tin plating)
              master hoarder
              • May 2008
              • 12175
              It would take a very long time to heat the capacitor before you destroy it: probably upwards of a few minutes where the capacitor body is above 200C. (After all, even electrolytic caps can withstand the heat of a nearby BGA chip being soldered/desoldered).
              Now, I've destroyed a number of Panasonic caps the same way like stj - basically the rubber bung started melting, and then the capacitor lead(s) started pulling out and messed up the capacitor internally. One managed to leak a little bit as well. Panasonic seems to use softer rubber bungs that melt at a lower temperature. Their advantage is, however, that the rubber seal withstands pressure better. So be careful when desoldering Panasonic caps.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                I was wondering what happened to that KMG (105°C) Chemicon capacitor. It took a while before I finally could get that capacitor out but I wasn't heating it for like 5 minutes straight (had to add solder and keep both terminals hot while jiggling before I could get it out.) There was more or less dried electrolyte all over the bottom and on the board indicating that it clearly leaked. I didn't hear any boiling/sizzling which probably vindicates me from damaging it during removal.
                I always try to remove capacitors carefully so I can test them and replace them if they test good OOC. Alas this one was clearly bad OOC as well as in situ so hence the jury rigged 'replacement'.
                I do wonder how hot it got for that capacitor to spill its guts, and surprisingly the other low voltage secondary caps look/test OK. Since the PSU works with the jury rigged capacitor, this ascertains the failure point and I now have to assume that the damage was done before I removed the capacitor.
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  Think i've done it once or twice, but not due to heat, rather to pulling too hard on one of the leads.
                  A working TV? How boring!
                  • Dan81
                    SNES-powered
                    • Oct 2013
                    • 1866
                    As funny as it sounds, I had that happen to a KZE out of a P4P800 SE motherboard.
                    Needless to say I used something else to replace it.
                    Main rig:
                    Gigabyte B75M-D3H
                    Core i5-3470 3.60GHz
                    16GB DDR3-1600
                    Samsung SH-224AB DVD-RW
                    Delux MG760 case
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8701
                      The other thing is that I thought that capacitor leads were welded to the foil internally, yet I've had pins pull out of the foil... is it due to the soldering or perhaps it was damaged well before then?
                        • Jul 2011
                        • 6040
                        I have had it were the pins have come out on a no name brand caps
                        I have not had any pins come on any KZE & KY I use them all the time
                          master hoarder
                          • May 2008
                          • 12175
                          They are.
                          But the foil is not what holds the capacitor leads from coming out - that's the bung's job. Think about what happens if you take a needle or two and put it through a piece of aluminum foil and then slide it down - it will easily tear, even if you have 10 of those needles. Same happens inside a capacitor when the bung is severely softened from heat during soldering/desoldering and you pull on a lead.
                          So that's why it's always a good idea to make sure the solder has completely melted before trying to pull a cap out. Otherwise you exert more force on the (heated) bung, and that can caused a capacitor lead to pull.
                          Like I mentioned above, I've had that happen more often with Panasonic that any other brand. In particular, I destroyed a number of Panasonic FL caps from when recapping a batch of P4SD motherboards. And this mainly happened when I started recapping those motherboards only with a 35W soldering iron, which clearly wasn't big enough for the task. I then switched to my 75W station, and no longer had that problem.
                          • Nier
                            Drilling out solder from capacitor holes
                            by Nier
                            I have an xbox 360 board that had 4 leaked electrolytic capacitors. I desoldered all 8-10 capacitors (1500uf 16v) since 4 leaked and wanted to replace all of them. 2 capacitor legs broke and were stuck in the through hole.
                            My two solder suckers just didn't work and I decided to use my dremel lite in the lowest speed to drill out the broken capacitor legs. I used a carbon drill with the exact diameter size as the capacitor hole. I drilled out the capacitor legs but I think that I damaged the holes. I don't think that the solder will adhere through the hole if If I solder a new capacitor....
                            10-05-2021, 09:48 PM
                          • liquidzorch
                            862D+ solder station iron out of control when fan on
                            by liquidzorch
                            Hello.
                            I have a soldering station, 862D+, and every time the hot air gun is on, even if it is just cooling off, the soldering iron controller stops controlling. Let me explain what has happened so far, as it took a while to get to this.
                            First, the switch that turns on the hot air gun started to fail, the light came on, but temp never rose, I would have to switch it multiple time to get the gun to start heating, this was due to the contact inside being carbonized. I opened the switch up, clean the contacts, and it would work fin for a while until carbonized again. So, I ordered a switch...
                            06-09-2022, 08:49 PM
                          • LaPCon_IT
                            iMac A2438, destroyed capacitor and coil.
                            by LaPCon_IT
                            Hi people.
                            iMac A2438, board 820-02009-06. Some insect has killed itself destroying capacitor and coil next to it. No chance for buying donor board, so I'm asking you for help about values of destroyed components.
                            03-16-2024, 09:32 AM
                          • acedogblast
                            by acedogblast
                            11-02-2024, 05:13 PM
                          • Prolog
                            by Prolog
                            12-01-2024, 08:27 PM
