Drilling out solder from capacitor holes
  • Nier
    • Aug 2020
    • 5
    I have an xbox 360 board that had 4 leaked electrolytic capacitors. I desoldered all 8-10 capacitors (1500uf 16v) since 4 leaked and wanted to replace all of them. 2 capacitor legs broke and were stuck in the through hole.
    My two solder suckers just didn't work and I decided to use my dremel lite in the lowest speed to drill out the broken capacitor legs. I used a carbon drill with the exact diameter size as the capacitor hole. I drilled out the capacitor legs but I think that I damaged the holes. I don't think that the solder will adhere through the hole if If I solder a new capacitor.
    My question is does the solder not only adhere to the upper and lower pads on the board but does it also adhere in through the hole? Is there a circular pad that also goes through the hole?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Drilling out solder from capacitor holes
    The holes can be plated, non plated and partly plated. Don't drill holes out, use these https://www.aliexpress.com/item/33004594843.html or a needle to clear the hole.
      master hoarder
      • May 2008
      • 12170
      Observe this diagram first:
      Now, it doesn't matter if you have the same exact Xbox 360 motherboard version as the one above. All of the 16V, 1500 uF capacitors in the Xbox 360 (old/phat console) are connected to the 12V rail. However, the 2x caps near the GPU VRM are connected together after a PI inductor, and the 4x caps near the CPU VRM are also connected together (after a different PI inductor). So technically you shouldn't connect the cap with the destroyed hole anywhere on the board's 12V rail. Depending on where that cap was, you will either have to connect it to a 12V point on the GPU high-side VRM, CPU high-side VRM, or 5V_aux high-side VRM... or perhaps if it was that lone 16V 1500 uF cap right by the power connector - that one is the 1st filter cap on the 12V rail before any of the PI inductors mentioned above, so connect that one directly to the power connector pins that have 12V power. Use multimeter to find these.
      As for drilling holes - DON'T DO IT! Ever. It will always damage the hole's via, and then you'll have more of a headache (but you probably already know this now :\ ). If a cap lead becomes broken and stuck in a hole, forget about using a solder sucker. Use needle-nose pliers and a regular iron to pull it out from whichever side still has something sticking out. In fact, I don't suggest anyone to be using a solder sucker for the Xbox 360 motherboards. Their ground planes are too thick, and unless you are really experience with your solder sucker or have a really high quality one, chances are, it will be harder to remove the caps with that than just using a regular soldering iron and rocking/"walking" the caps back an forth, as shown by this method:
      https://www.badcaps.net/forum/showpo...7&postcount=23
      All of that aside... I'm curious - what brand and series were the 4 leaked electrolytic caps you found? Were they the 16V ones or 6.3V ones? If they are the 16V ones, see this thread for proper replacements (and which brand and series to beware of for the 16V caps):
      https://www.badcaps.net/forum/showthread.php?t=98012
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • corrize
        Best way to solder LVDS connector for beginner (and qfn) ?
        by corrize
        Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
        I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
        I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
        See the test :
        https://youtu.be/bNAzC-EvqHs?t=1767
        With hot air from bellow the board, that's...
        03-09-2023, 02:57 AM
      • SluggerB
        Would this be safe?
        by SluggerB
        I am trying to fix a broken plasma TV by replacing a large cap on the power board. It is a 1900uf 220v cap and I could only find one place that sells them. It was listed as through hole, so I bought it. It showed up today, but instead of through hole, it has spade connectors.
        Would it be safe to get some heavy duty wire (like lamp cord wire), connect that to spade connectors, connect them to the spades on the cap, and run the other ends of the wire 2-3 inches to the holes and then through the holes and solder them in place? I actually did it already and put it together but...
        06-04-2025, 04:22 PM
      • televizora
        Drilling holes laptop bottom
        by televizora
        I wonder if drilling a few holes in the laptop case, on the bottom below the fan will actually help and decrease the CPU/GPU temps. I have one spare not so new laptop with first gen core i5, but the main issue is that while the cooling systen is clean, it runs rather hot - youtube tends to bring the laptop to about 60-64 degrees, even if power plan with 60% power limit restriction is used and the cpu itself does not go above 1.2-1.4GHz. It has integrated graphics, this is true, but the temps seem a little bit high... Even the SSD runs above 55-60 degrees, while it isnt actually intensively used......
        08-04-2021, 09:49 AM
