Need help to identify this cap
  • longlong2k
    • Mar 2010
    • 4
    Can you help me to identify this cap? It reads MPA .033G630P.
    My guess is this is a Metallized Polyester Film Capacitor of some sort of 0.033uF 630V. However, I have no way to validate whether I guess correctly or not.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Need help to identify this cap
    I would say your guess is right. Have you measured capacitance?
    • longlong2k
      • Mar 2010
      • 4
      I am totally new to this. Can you advise how to measure capacitance?
      • dskall
        • Oct 2016
        • 2905
        • usa
        Your multimeter should read capacitance
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          You right. Metallized Polyester Film Capacitor....0.033uF 630 V
          • PeteS in CA
            • Aug 2005
            • 3581
            • USA, Unsure of Planet
            Might the "G" mean 2% tolerance?
            In other contexts:
            M = 20%
            K = 10%
            J = 5%
            G = 2%
            F = 1%
            B = .1%
            PeteS in CA
            • thesame
              DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
              by thesame
              Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
              The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
              02-27-2024, 04:31 AM
            • silver60618
              Lenovo Legion 7 - Help Identify IC
              by silver60618
              Hi gang, its a long shot, but working on Lenovo Legion Pro 7 motherboard NM-F091, and trying to identify this component near GPU with marking "eHFQH" that is burned and shorting the board. Looks like power management IC
              I couldnt find any schematic or boardview. The CPU side also has same chip. Any way to identify this chip? or take measurements from the good chip to determine what it is?
              Any help would be appreciated...
              07-02-2025, 12:16 PM
            • chth96
              How can I identify varistor which have been blew up?
              by chth96
              I mistakely pluged 100v japanese retro game console to 220v outlet.
              So It seems that glass fuse and varistor have been blew up.
              I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
              Is there any way to identify varistor type in my sega saturn PSU?
              Any reply would be appreciated.
              EDIT:
              It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
              11-26-2023, 08:52 AM
            • freakorio
              Need Help To Identify Component on Ymain LJ41-05120A
              by freakorio
              Hi guys , i hope this is the right place , i got Plasma Samsung PS-50Q91H and i need to repair Ymain LJ41-05120A , but those component are burn and i can not identify to replace those part , and the part are blue capacitor and the location are C5105 and C5106 and here i attach the part that need to identify , and one more thing , i also need to replace Zener Diode on location ZD5502 and the part are BZV55C because mine is short but i don't know the voltage because those parts are release with many type of voltage. Looking forward for your kindly reply
              05-21-2024, 02:32 AM
            • baiceanu_stefan
              nm-f251 Schematic, boardview or help identify componente
              by baiceanu_stefan
              Hello, I have a legion pro 5 16arx8 serial number pf4bf4aw mb code nm-f251 rev1.0 which was dissasembled by the client for cleaning. Now it does start but for 20 secs after that fans run at maximum and then shut down. Found PU8302 burned but cannot identify it the part. It is written eHFAA on it but didn't found any info, no boardview, nothing. Can anyone help identify the part so I can order it from somwhere? Ataching some pictures of the motherboard, serial number and part. Than\k you...
              04-24-2024, 12:49 AM
