Bad cap or not ?
  • naughtycap
    • Jun 2017
    • 5
    • poland
    Bad cap or not ?
    Hi
    Here is a capacitor inside a faulty Moog MF-104Z delay pedal. What do you think ?
    I -might- have fed the unit 15 volts instead of 9v....
    • 31303
    Re: Bad cap or not ?
    what does it say on the other side?
    • naughtycap
      • Jun 2017
      • 5
      • poland
      here's a pic :
        • 31303
        so why the concern, it's rated upto 50v
        • naughtycap
          • Jun 2017
          • 5
          • poland
          allright
          thanks !
          • CG2
            Janome DC3050 Sewing Machine Pedal Resistance
            by CG2
            OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
            Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
            04-14-2023, 07:53 AM
          • u666sa
            HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
            by u666sa
            Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
            Platform: ipa32 la-m024p rev 1b
            Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
            I found a short on the other side:
            10-04-2025, 05:03 PM
          • MisterAIL
            PS5 digital / No Power / No Beep / Good power supply
            by MisterAIL
            Brought a non functionnal PS5. Apparently only a bad PSU...
            No beep, nothing.
            After some tests i found this :
            - PSU is fine (12 volts stable)
            - 12 volts line is shorted
            - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
            - By the way, nothing change. No signal, no power, no beep.
            Mesuring all rails with my workbench psu (12 volts input)
            - 0.00 amp drawing
            - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
            03-12-2024, 03:24 PM
          • supermattch
            HP 15dy-2021nr wont power on mystery volts
            by supermattch
            Hi everyone.
            I am diagnosing my personal laptop, because it wont power on and no leds light up.
            At the dc-in there are 8 pins, 1 and 2 shows healthy 19.66 volts. The next three are ground, but the 6th one shows .283 volts. This is strange to me, it should be 3.3 or 5 or aome volts not 0.283v. As I am new to this, I would like some guidance. Please someone advise me on what to check next.
            Oh the boardview and schematics I am using is for a similar model as I cannot find the proper one anywhere. Quanta DA0P5HMB8F1 rev F. Nowhere on the internet.
            09-23-2025, 12:13 PM
          • Mcfeetroy
            Fishing bite alarm drains battery
            by Mcfeetroy
            Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
            08-01-2025, 03:52 AM
