I really have been trying to do my own research here and it seems that every time I think I know what values I need, something changes, or I really DON'T understand them as well as I thought.
Scenario is that I use a HDD player in my shop via toslink, the weather started getting warm a week ago and I couldn't shut it off. I pulled the plug, let it cool down, fired it up to make sure it still worked, brought it inside then opened it up and found a cap that had bulged/vented.
I'm not an electrical engineer however, I have no problems with a soldering iron and caps, opamps, plugs, wires. I am just uncertain of which values specifically to replace these (apparently infamous) caps with?
There are two specifically marked with the HERMEI brand that will be replaced. The one that is bulged is the only purple/silver, while the others are more normal looking Black/Grey.
Purple/Silver is labeled as
LZ 105C*
0949
470uF 16V
Black/Grey is labeled as
HT105C*
0949
470uF 10V
I believe I have found both of the data sheets for the LZ and HT series caps (THX to the links from this site) but am having some difficulties in cross referencing their values with something of a better build quality ie. Nichicon, Ruby, Pana. Any help would be GREATLY appreciated.
Forgot to attach the PDF.s LoL
LZ 105C*
0949
470uF 16V
HT105C*
0949
470uF 10V
