Replacement Caps for bulged HERMEI??
  • Akashajeep
    • Jun 2017
    • 22
    I really have been trying to do my own research here and it seems that every time I think I know what values I need, something changes, or I really DON'T understand them as well as I thought.
    Scenario is that I use a HDD player in my shop via toslink, the weather started getting warm a week ago and I couldn't shut it off. I pulled the plug, let it cool down, fired it up to make sure it still worked, brought it inside then opened it up and found a cap that had bulged/vented.
    I'm not an electrical engineer however, I have no problems with a soldering iron and caps, opamps, plugs, wires. I am just uncertain of which values specifically to replace these (apparently infamous) caps with?
    There are two specifically marked with the HERMEI brand that will be replaced. The one that is bulged is the only purple/silver, while the others are more normal looking Black/Grey.
    Purple/Silver is labeled as
    LZ 105C*
    0949
    470uF 16V
    Black/Grey is labeled as
    HT105C*
    0949
    470uF 10V
    I believe I have found both of the data sheets for the LZ and HT series caps (THX to the links from this site) but am having some difficulties in cross referencing their values with something of a better build quality ie. Nichicon, Ruby, Pana. Any help would be GREATLY appreciated.
    Forgot to attach the PDF.s LoL
    • 31170
    Re: Replacement Caps for bulged HERMEI??
    LZ
    470/16 8mm x 10mm 0.042r 850ma
    FR
    470/16 8mm x 11.5mm 0.056r 950ma < close enough.
    HT - general junk.
    i would just fit a pair of FR's
    • Akashajeep
      • Jun 2017
      • 22
      Thank you!! Very much appreciated
      • PeteS in CA
        • Aug 2005
        • 3581
        • USA, Unsure of Planet
        Some general junk knowledge you might find useful:
        LZ - Series name, as you learned
        105C* - rated to operate within spec up to 105 degrees C
        0949 - date code, 49th week of 2009
        Even though Hermei isn't a great brand, that part lasted about 7 1/2 years, which is not too bad. Either you got lucky in the reliability lottery, or the manufacturer of that HDD player used it well.
        The series stj recommended is made by Panasonic, a very good brand. Digi-Key might carry that part. Also, there is a very similar part - same case size - in Nichicon's HV series, which Digi-Key might carry.
        PeteS in CA
        • Akashajeep
          • Jun 2017
          • 22
          0949 = Date code! The mystery has been solved!! LoL, I really didn't know that. But yes I DO take very good care of my electronics. This is the first year I have had that HDD player in my shop as it is usually inside my "equipment rack" which is cooled by numerous fans. I did Frankenstein the top of the player so it now has X2 80MM fans pulling air out. Honestly I think I have to take more blame in the fault of that cap as it was pushing 100*F easy, in the shop for 5-6 hours!!
          • Akashajeep
            • Jun 2017
            • 22
            I think the main part that was throwing me off was the fact that the data sheet gives values for the impedance max @ 25*C AND -10*C (100kHz) in standard Ohm readings while the Mouser/Digikey part finders are in mOhm format. As well as the small variations between the charted "Ultra low imp, High ripple" vs. "STANDARD SIZE, RATED RIPPLE CURRENT" which I can't deduce any markings on the caps themselves to indicate what they in fact are.
            • black6host
              Replacement caps for Samson Resolv studio monitor 65A Amp board.
              by black6host
              Good day!
              I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
              I'm going to replace the caps and I'll be the first...
              02-06-2024, 08:22 PM
            • rewease
              Replacement for the Siemens Bakelite caps in an early 1980s SMPS
              by rewease
              There actually was a time when early SMPS and late bakelite housed electrolytic caps coexisted in high end industrial gear. A friend of mine just got himself a CNC milling machine form that time with its first set of now 41 year old caps still installed in the PSU... and it's malfunctioning.
              Two of the caps have already leaked slightly onto the board. I have not desoldered or measured any so far but they should qualify for replacement.
              Now I'm wondering what to put in there as a replacement. First idea was state of the art low-ESR Nippon KY,...
              09-17-2023, 12:53 AM
            • crosswinds
              Assistance with identifying replacement caps on ASUS P5VDZ-MX
              by crosswinds
              So, pulled a motherboard out from storage, was working when put away, wont post when I took it out of storage today.
              Since it was working, and it looks to be essentially time that killed it I figured its a good idea to replace the caps before digging further.
              Looks to be only good quality caps on this board, so might not be the issue. But it is closing in on 20 years now so, wont hurt i guess
              Its a ASUS P5VDZ-MX board.
              I would really appreciate some assistance on what the best replacement caps would be for these:
              Panasonic(M)...
              04-17-2024, 04:25 PM
            • HectoPascal
              Replacement caps ok? (smoothing caps, PSU heating controller)
              by HectoPascal
              Hallo,
              i want to replace two smoothing caps from a heating controller PSU. They are probably 30 years old and it might be time to replace them.
              SXE 470uF 63V 105°C (tested: 472uF 0.35Ohm) --> Nichicon VY 105°C - 463uF 0.15Ohm
              SXE 470uF 25V 105°C (tested: 422uF 0.63Ohm) --> Samwha K5A 85°C - 446uF 0.10Ohm (or Panasonic RAD FC 470/25 8mm)
              I couldn't find anything about 'SXE'. That's the only declaration on the caps. Edit: The top/bottom ident says Nippon CC.
              Nichicon should be 'VY' series (linked).
              I couldn't find anything about Samwha...
              09-06-2023, 08:30 PM
            • Ruts
              PS5 EDM-033 Caps values near Southbridge
              by Ruts
              Hi
              I managed to knock off two capacitors on a EDM 033 board near the southbridge and BIOS chip.
              Does anyone know the values of these capacitors?
              09-15-2025, 06:00 AM
