looking for 2200uF 16V 10x20mm
  • ajdrenter
    Picking caps for Antec SU-380
    by ajdrenter
    In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
    https://www.badcaps.net/forum/showthread.php?t=14159
    It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
    05-13-2023, 10:40 AM
  • bjs59
    Infamous Rubycon MFZ... Current recommended replacements???
    by bjs59
    What we have here today is an Intel DG33FB motherboard, circa 2007... I need to replace some of the caps on this board... From what I have found, one of these caps was sort of well known here back in the day as they were used in XBoxes and XBox 360s as well....They are the Rubycon MFZ series, in particular the 6.3 v 3300uf 10mm X 20mm... I have found a seller on Amazon, The Capacitor Store, that has them listed but I have a hard time believing these are genuine pieces... The original recommendation was to replace any bad ones with Nichicon HZ series since the Rubycon MFZ's were a custom product,...
    12-10-2020, 10:47 AM
  • quickname
    Cyberpower 1500AVR UPS repair
    by quickname
    I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
    I decided to verify that the batteries were...
    11-12-2023, 09:57 AM
  • Oldschool297
    Motherboard K7N2 Delta-L Socket A 462.
    by Oldschool297
    I wrote about a Asus board with bad caps and i have this to. There seems to be 6 bad 1000uf 10v Michicom? Michigan? Do you know any good manufactors?
    I got it to work last year, i could install Vista but the cpu seems to go high even if i had the right paste. 55-60 Could it have been because of the caps? I changed cooler but it was the same. When i should start it another time nothing appears on the screen, only black. Some said it could have been the bios chip but the caps spoke more to me. I also discovered that the board did not start sometimes, but when i touched a cap a little it seems...
    07-17-2023, 10:13 AM
  • MeltedDuron
    A1289 Mac Pro "Early 2009" PSU (ACBel FS8001-291H, 614-0455)
    by MeltedDuron
    So a couple of days ago I picked up a 2009 8-core Mac Pro in "as seen" condition at a price that was too good to pass up, got it home, eventually managed to install OS X on it, and then it died while downloading updates. This machine looks like it was used for heavy video editing work as it still had a Blackmagic capture card and two GPU's installed, but I expect we'll see a lot more of these 2009 Mac Pro PSU's failing soon.
    After it died, the machine made some clicking noises, like it was trying to fire a relay but something wasn't working right, so it kept randomly clicking...
    02-14-2020, 11:40 AM
