I wrote about a Asus board with bad caps and i have this to. There seems to be 6 bad 1000uf 10v Michicom? Michigan? Do you know any good manufactors?
I got it to work last year, i could install Vista but the cpu seems to go high even if i had the right paste. 55-60 Could it have been because of the caps? I changed cooler but it was the same. When i should start it another time nothing appears on the screen, only black. Some said it could have been the bios chip but the caps spoke more to me. I also discovered that the board did not start sometimes, but when i touched a cap a little it seems to start. One was little glitch.
In 2001 the faulty capacitors on motherboards was due to a mis-copied formula. In 2001, a scientist working in the Rubycon Corporation in Japan stole a mis-copied formula for capacitors' electrolytes. My rubycon 2200uf seems whole, strange. (It seems high, 2200. I only got that number on this board as i know) The mess with the cooling paste was not me, it was so when my sister first got it many years ago. The cpu works in another board so it can't be that.
