DELL GX280 problem-help!!
  • cn_tony
    • Dec 2008
    Just got one from auction, after power on, can see DELL logo, then screen has little flick and become blank after 10 seconds. Checked google, and opened the case found three nichicon 820uf, 6.3V caps near RAM slot, they all bulged. all other capacitors are fine, they are panasonic or rubycon with flat top. I replaced three nichicon caps with other three caps which are 1000uf 6.3V, 105C, but still has same symptom-blank screen after boot up.
    Question is, do I need to sold the exactly same parameter caps? Do I need to sold a some kind of low ESR caps? Because the size of new one is even smaller than bad nichicon one.
    Thanks in advance for any good comments.
  • cn_tony
    • Dec 2008
    Re: DELL GX280 problem-help!!
    Finally found the culprit, the LCD screen, dell 1901fp. it may be capacitor issue again. LCD screen flicking then blank. I need to open and check it.
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • Akhlz001
      by Akhlz001
      09-20-2025, 07:15 PM
    • master3112
      by master3112
      07-29-2025, 01:55 PM
      Dell Thunderbolt Firmware
      by SMDFlea
      Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
      Some models have a choice of 2 different firmwares, it depends on the dell SKU.
      The SKU is in brackets (****)
      EDIT: NVM65...
      01-26-2025, 06:22 AM
    • dell_sadness
      Dell Latitude 3440 - Service tag ending in 0001 - Locked!
      by dell_sadness
      BIOS password locked Dell Latitude 3440 (Service tag B4HNJX3)
      Have extracted the BIN and want to know how to rebuild a clean BIOS
      I have come across the 8F8C patcher but not sure if that would work in my case as the service tag ends in 0001.
      I tried it and although the log states it patched several mentions of 8F8C in the BIN, I haven't flashed it yet in case such a patch wouldn't work.
      Have also tried to extract a clean BIN file from Dell's .exe BIOS updates using 'Dell PFS Extractor', but not confidently; Ended up with a 25MB file instead of the same 32MB...
      11-12-2025, 02:54 PM
