DELL GX280 problem-help!!
  • cn_tony
    • Dec 2008
    Just got one from auction, after power on, can see DELL logo, then screen has little flick and become blank after 10 seconds. Checked google, and opened the case found three nichicon 820uf, 6.3V caps near RAM slot, they all bulged. all other capacitors are fine, they are panasonic or rubycon with flat top. I replaced three nichicon caps with other three caps which are 1000uf 6.3V, 105C, but still has same symptom-blank screen after boot up.
    Question is, do I need to sold the exactly same parameter caps? Do I need to sold a some kind of low ESR caps? Because the size of new one is even smaller than bad nichicon one.
    Thanks in advance for any good comments.
  • cn_tony
    • Dec 2008
    Re: DELL GX280 problem-help!!
    Finally found the culprit, the LCD screen, dell 1901fp. it may be capacitor issue again. LCD screen flicking then blank. I need to open and check it.
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • Akhlz001
      by Akhlz001
      09-20-2025, 07:15 PM
    • master3112
      by master3112
      07-29-2025, 01:55 PM
    • F R 2568
      Dell Latitude 5420 does not start (no post) need help to find the reason why
      by F R 2568
      Hello all,
      this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
      I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
      If the laptop is only connected to the AC adapter (battery removed):
      When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
      The power/battery...
      01-08-2025, 05:45 AM
    • diamon
      Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
      by diamon
      I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
      Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
      Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
      Pictures of these boards:
      Dell Latitude 5520 https://www.ebay.com/itm/256052956663
      Dell Latitude 5530 https://www.ebay.com/itm/125844181534
      Dell...
      02-28-2024, 12:51 PM
