Capacitors for an oven display
  • RukyCon
    A Fake Rubycon
    • Jan 2017
    • 816
    Hello, i need some help finding some capacitors for an oven display.
    The capacitors i need are...
    68UF 35V 130C to 150C
    And possibly some
    470UF 35V 130C to 150C
    I need high temperature capacitors do to the poor thermal insulation.
    I'm not a expert, I'm just doing my best.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Capacitors for an oven display
    Use digikey's parametric search.
    Vishay has 68uF 35V in 125C.
    Panasonic has 470uF in 125C.
    For 68uF 35V, try going up a bit in voltage to see if you can get 135C.
    Rubycon RX series goes up to 130C for ballast.
    http://thecapking.com/50rx3047.html
    --- begin sig file ---
    --- end sig file ---
    • RukyCon
      A Fake Rubycon
      • Jan 2017
      • 816
      I can not find anything good for the 68uf 35v cap.
      • redwire
        • Dec 2010
        • 3907
        But the rest of the board will not take 130-150°C anyway. PVC wires melt- Bunn coffee makers use all teflon wire. MCU and semiconductors can't take that much heat too.
        It's easier to put the PCB (or big caps) in a cool place or get some airflow.
        I think only MLCC ceramic caps can take such heat. The wet ones like tantalum & electrolytic- heat is very hard on them.
        They are a specialty, expensive cap http://www.kemet.com/Hi-Temp-Ceramic
        • RukyCon
          A Fake Rubycon
          • Jan 2017
          • 816
          I'm not sure how to get the PCB into a cool environment or how to get some airflow on it.
          And i'm not sure where to look for the high temperature ceramic capacitors.
            Digikey?
            • redwire
              • Dec 2010
              • 3907
              Digikey offers no 35V-50V high temp MLCC's above 10uF.
              I did see 25V parts, biggest is 15uF X8L or 4.7uF 50V.
              If the controller board is located near a vent, under the oven, it is cooler and you get some airflow. I just think high temp caps would not help much.
              Surely it has a relay or SSR to switch the heating element. These parts can't take over 105°C because they generate their own heat, so I think they would have a short life.
              Next is adding a cooling fan for the board, or a heat shield.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8146
                Newark Canada (Element 14) has 35V 470uF @135C rated Panasonics TP series. The 68uf capacitor you may have to go to a 100uF, as I haven't seen it.
                • RukyCon
                  A Fake Rubycon
                  • Jan 2017
                  • 816
                  The controller board is located in the top of the oven...
                  And adding something like a fan dose not seem like it will keep the board cool [unless i do something crazy like cut a hole in the panel.]
                  Now how do i find a heat shield?
                  • cagiva4ever
                    • Sep 2011
                    • 22
                    well, is it possible to re-locate the Capacitors faraway from the hot place ?
                    adding needed lenght of wiring between caps and pcb, instead of soldering them into PCB directly ?
                    that would give also many cooling solutions for them caps,w hen located freely...........
                    • RukyCon
                      A Fake Rubycon
                      • Jan 2017
                      • 816
                      At this point i'm just going to get some 100uf caps to replace the 68uf one.
                      • RukyCon
                        A Fake Rubycon
                        • Jan 2017
                        • 816
                        Should i get this EPCOS capacitor... [100uf 35v 150c 1000h]
                        https://www.digikey.com/scripts/DkSe...46830413829537
                        Or this rubycon capacitor... [100uf 35v 130c 2000h]
                        • redwire
                          • Dec 2010
                          • 3907
                          I didn't know automotive electrolytics rated to 150°C exist, $0.75 100uF 35V.
                          For every 10°C cooler, you double the cap's lifetime.
                          So 1,000hrs@150°C and ~5,000hrs/130°C rated. The Epcos B41868W7107 one looks better.
                          I'm not sure what the oven looks like. But having the control board at the top of the oven is the worst place for it. My point is the rest of the electronics wiring/relays/semi's/connectors will have a hard time with such high temps.
                          • RukyCon
                            A Fake Rubycon
                            • Jan 2017
                            • 816
                            Ok then i will go with the Epcos 150c cap.
                            • RukyCon
                              A Fake Rubycon
                              • Jan 2017
                              • 816
                              I have the capacitors but i have not installed them yet.
                              May get to it on the weekend.
                              • dragon3x
                                by dragon3x
                                power on.
                                Here are some examples :
                                switching supply area).
                                than 6.3 V.)
                                03-21-2025, 02:46 PM
                              • slybunda
                                AA and AAA battery charger capacitors?
                                by slybunda
                                hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                                it has inside:
                                2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                                2 x 470uf 16v LZ105c branded as G.Luxon
                                not heard of these brands are they any good?
                                iv attached photos of the charger and the board inside for an idea on the type of...
                                12-24-2023, 04:41 AM
                                After all of...
                                07-13-2024, 08:14 PM
                              • Ady2017
                                Are there any datasheets available for Elna RJG capacitors?
                                by Ady2017
                                I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                                05-25-2025, 02:19 PM
                              • Fsufan1391
                                LG Oven model LREL6325F
                                by Fsufan1391
                                Hello everyone my oven is less than 2 years old and all of a sudden recently when i run the oven for 15 minutes or so and i am done with it and shut it off. after about 10 minutes it starts chiming and randomly putting it in different modes like the touch screen is being touched but no one is around it. I have tried to reset it by unplugging it multiple times and no luck. I took it apart to see the main board and everything looks fine. I am wondering if i should replace the main board or if its in the control panel. the touch screen is very responsive and works like it should. its only acting...
                                04-23-2025, 05:42 AM
