Capacitor ESR
  • roadrash
    • Oct 2015
    • 492
    • U.K.
    Capacitor ESR
    I have been told the best way no be sure of a Visually good capacitors true condition is to measure its ESR. However I am still confused as there doesn't seem to any specific value of this. Some manufacturers data sheets for capacitors don't even give the ESR rating of thier capacitors. For example (1)
    I have here a Nichon 25v 220uf electro cap that according to my GM328R component tester has the following values: Impedance 228.4 ohms, vlos 2% and a ESR:0.40 ohms. As i cannot find any specs on what a acceptable ESR should be How do I know whether this is a good or bad cap. Example 2 is a nichon 4700uf 10v electro cap and it tests are: uf=5293 uf, vlos=1.9% ESR=0.16 ohms. Are these caps good or bad? Some caps I have measured have impedance in the fractions of a ohm while others can be many ohms. Is there a rule or baseline for knowing when a cap is in tolerance and a acceptable usable condition.
    • 31289
    Re: Capacitor ESR
    i suspect both those caps are fucked - specially the first one.
    esr is only missing from datasheets of 85' general purpose caps.
    for those, there are vague charts printed on early meters.
    here's one.
    • roadrash
      • Oct 2015
      • 492
      • U.K.
      Re: Capacitor ESR
      here's one.
      Thanks that's very handy. Apologies I didn't notice the decimal point ahead of those ESR figures, I wish they would put a leading zero as the decimal pint is not easy seen so are these caps still U/S?
        • 31289
        Re: Capacitor ESR
        if it's under an ohm it's probably o.k.
        unless it's a low impedence type - then we need the datasheet.
        you didnt say what series either of those caps are.
        • roadrash
          • Oct 2015
          • 492
          • U.K.
          Re: Capacitor ESR
          unless it's a low impedence type - then we need the data sheet.
          you didn't say what series either of those caps are.
          Thanks that's what I have been wanting to know ever since I got this tester was what is a good value of ESR. Not sure about this caps series but the caps are marked -40~+105c T N(M) Vent. I'm determined to learn this smps stuff repair and I must admit I'm starting to understand it now a bit better.
            • 31289
            Re: Capacitor ESR
            http://www.paullinebarger.net/DS/Nichicon/
            • roadrash
              • Oct 2015
              • 492
              • U.K.
              Re: Capacitor ESR
              Wow thats great. So does that mean these are CY or CS series caps?
                • 31289
                Re: Capacitor ESR
                i wouldnt know - you didnt upload a foto of them.
                • roadrash
                  • Oct 2015
                  • 492
                  • U.K.
                  Re: Capacitor ESR
                  I was going by what the Temp specs were on the cap and finding a cap with the same rating. How are you identifying the Series? Here are some pics
                    • 31289
                    Re: Capacitor ESR
                    SXP series.
                    and it's what they call a "snap-in" terminal, large can type.
                    http://www.paullinebarger.net/DS/Rubycon/
                    i dont see it there, but a search will probably find it.
                      • 31289
                      Re: Capacitor ESR
                      btw, it's smoothing the mains,
                      so ESR is not important, but ripple-current is.
                      more is o.k. - less is bad.
                      • roadrash
                        • Oct 2015
                        • 492
                        • U.K.
                        Re: Capacitor ESR
                        I understand the reason for smoothing from all my swatting on SMPS I believe its rectified after this isn't it? So do you think these caps can be refitted or do they need replaced? They do look in perfect condition. I have replaced all the other caps including the one by the coloured label that was pointed out to me in my other "Amiga PSU" thread in the Power supply section of this forum.
                        • pfofit
                          • Jun 2008
                          • 10
                          Re: Capacitor ESR
                          howdy.
                          Initially you were talking about specs measured on Nichicons but you showed a pic of a Rubycon.
                          Attached is an old copy of that SXP series, no esr data, but has ripple current spec dependent of physical size.
                          Typically the series is a 2 or 3 alpha numeric designation.
                          Esr will vary by series and manufacturer. Also is dependent on capacitance. temperature rating and physical size.
                          There is no hard fast rule, but experience will help.
                          Data sheets are necessary.
                          • roadrash
                            • Oct 2015
                            • 492
                            • U.K.
                            Re: Capacitor ESR
                            Originally posted by pfofit
                            howdy.
                            Yes your right, that was just a example cap I was using. I have these other 2 caps on this PSU I am doing that I am unsure need replacing and they are a perfect example of another Cap that looks perfect and I would like my ESR tester to tell me whether they are usable or not. I don't see the point of replacing caps that are OK and like STJ says are less likely to go bad anyway.
                            • MORETTIGIAN
                              Capacitor detached from PCB – RTX 2070 Super Founders Edition
                              by MORETTIGIAN
                              Title:
                              Description:
                              During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                              I did not notice it detaching, so I am unsure of its original location on the PCB.
                              Procedure performed:
                              - Removed backplate
                              - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                              - Reapplied thermal compound
                              - Reassembled card
                              Observed behavior after reassembly:
                              - GPU powers on and operates normally under...
                              09-18-2025, 12:14 PM
                            • Prolog
                              RTX 3080 FE Identifying capacitor
                              by Prolog
                              Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                              I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                              I hope these photos make it clear which component I am referring to:
                              (yes, the soldering is a bit botched from removing the blown one, I know)
                              I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                              12-01-2024, 08:27 PM
                            • Agent24
                              Dick Smith Q-1760 linear power supply filter capacitor question
                              by Agent24
                              I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                              It has at least one problem.
                              The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                              I have already ordered a replacement potentiometer, so that's not an issue.
                              Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                              All are CapXon...
                              10-21-2025, 05:39 PM
                            • chth96
                              If I replace with inferior capacitor, Is it No harm to other IC components at all?
                              by chth96
                              I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                              Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                              It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                              So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                              I know that these capacitor will not last as long as nichicon capacitor...
                              12-22-2023, 04:34 AM
                            • chth96
                              How can I test non-polarized capacitor?
                              by chth96
                              I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                              I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                              And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                              I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                              06-02-2024, 07:31 PM
