Does it matter: Replacement parts almost the same
  • noob4lyfe
    • Nov 2016
    I have a Toshiba LCD TV-55zv650u, and it's not turning on. I've narrowed it down a few components on the power board to replace:
    Regulator- STR Y6456 9502A
    Fuse- RGDU5M-5E 1.8 ohm J
    I'm currently searching for these parts with little luck.
    I found this one part that's STR y6456 0502A. And the difference is in between one number- 9 vs. 0 for the component.
    Is that a big deal? Does it have to be identical?
    • 31301
    Re: Does it matter: Replacement parts almost the same
    9502A is not important - it's the date it was made.
    your looking for STR-Y6456
      master hoarder
      • May 2008
      • 12175
      That "regulator" is actually a PWM-FET combo IC for power supplies. The actual part number is STR-Y6456, and that's all you need to look for. The mismatch in numbers between 9502A and 0502A doesn't matter, as that is likely a production date code and/or lot number indicator.
      Anyways, what makes you think that PWM-FET IC is blown? Is the fuse blown (reading open-circuit)? We could help more if we know more.
      *edit*
      stj beat me to it. See his attached datasheet.
      • noob4lyfe
        • Nov 2016
        Hi all. Appreciate the prompt response!
        stj & momaka- Thanks for clearing that up. Makes sense now !
        I essentially followed the instructions from this video( https://www.youtube.com/watch?v=ttrS...ex=103&list=WL). Used my own volt meter, and found my unit to have tested the same ratings for the good & bad caps.
        I'm looking at these parts for the IC. However I get a wide range of prices:
        $2.50
        http://www.ebay.ca/itm/1PCS-Power-MO...IAAOSwhkRWg-LR
        $13.50
        http://www.ebay.ca/itm/STR-Y6456-STR...wAAOSwImRYIPsZ
        Its the same brand etc. Despite the difference in quantity. Do you think there's an actual difference in quality? Is the first link too good to be true?
        I'm also stuck in terms of the brand that offers this IC part, as everyone is selling the same piece.
        The resistor is an Ohmite brand ($3), which I've read is reliable. With shipping totals to approx $15.
          So are you getting <10 Ohms between pin 1 and pin 2 of the STR?
          The fusible resistor shows >5 Ohms?
          • R_J
            • Jun 2012
            • 9631
            That one for $3.37 cdn plus $4.04 shipping comes from China, could take about 2 - 3 weeks, probably comes via china post (Canada post)
            that one for $18.12 plus $18.48 comes via the USA and most likely came from China, You could also get charge broker fees and taxes from the usa
            I would order the one from China
            or from UTsource https://www.utsource.net/search.aspx...R-Y6456&page=1
              • 31301
              cheaper from here:
              https://www.aliexpress.com/item/STRY...851726448.html
              $4 canadian all-in.
              • tvtimmy
                • Mar 2015
                • 1160
                • usa
                I have a rgdu5m-5e that reads dead short or .0000 ohms out of circuit. It makes me think the "fuse" part of it is working but with no resistence I think it is bad and sending a fault back to the mainboard. What do the smarter people than me think?
                  • 31301
                  i think it's fine.
                    What scale of the Ohm meter are you on?
                    .0000 ohms: Your probes resistance are that good?
                      • 31301
                      i think you would have to spend close to a $1000 on a 7.5digit or 8digit meter to get that level of accuracy!
                      • tvtimmy
                        • Mar 2015
                        • 1160
                        • usa
                        No, I only spent about $9 on a $60 Radio Shack model. Store was closing. It doesnt read .0000 but it was showing shrt(short). I replaced it with a 2.0 ohm I had in a parts bin and the tv turned on! Too bad the piece of crap Toshiba's seine board started on FIRE!
                        I did the reasonable thing, punched the screen out, said a few F bombs, and threw it in the back of my truck. I really dont like Toshibas..LOL
                        • boosti45
                          Macbook pro logic board replacement parts quesion
                          by boosti45
                          i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
                          08-21-2024, 05:23 AM
                        • samoelec
                          Trying to understand how to find best replacement cap for old parts.
                          by samoelec
                          Disclaimer: This is the first time I step into the realm of analog electronics and my natural language is not English, so please forgive me if I failed to use the correct terms when describing things.
                          Recently I purchased a Tektronix TDS1012, a 20 years old product for cheap and I thought it could be a nice opportunity for playing (i.e. recapping) and learn something in the process.
                          The power supply board is exactly the same from this post so I'll just steal it for now.
                          I'm trying to find replacements for all those Lelon electrolytic caps, but then quickly...
                          04-01-2024, 03:39 AM
                        • tranthengoc92
                          Looking for MSI replacement parts GF76-11UEK
                          by tranthengoc92
                          Hi everyone. I caused a short by removing the eDP cable without unplugging the battery. A component near the connector smoked. Does anyone know the value/part number of this burnt component? Looks like it's part L9 in the schematic...
                          11-21-2025, 08:28 PM
                        • H H
                          3090 FE Part Confirm/Identification
                          by H H
                          I'm hoping someone could help me confirm if I have identified the following parts correctly.
                          Apparently the DP cable became stuck inside the graphics card and was yanked out. This caused some sort of short which burned the DP contacts and blew some resistors and ferrite beads.
                          The parts needing replacement are on the back of the board behind the HDMI input.
                          I have identified the parts as the following:
                          C6037: MLCC 0.1uf/16v(0402)x7R W05
                          R6016: RES 499 OHM 1/16W (0402) 1%
                          LB10911: Ferrite Bead (0402)...
                          02-16-2025, 01:09 PM
                        • Mark D
                          Samsung UN65JU67ODFXZA Version TD01 Schematic and Parts List
                          by Mark D
                          The TV is a Samsung UN65JU67ODFXZA Version TD01. I replaced the power source board and the TV is now working, but I decided to try and troubleshoot the old board to fix at the component level. Trying to get a schematic and a parts list has proven to be an issue. Trying on my own, I can't tell you how many times my Norton security has flagged sites as "malicious". I ordered a service manual from ServiceManuals.net, paid $16.99 and got 66 pages of everything BUT schematics and component parts list! Can anyone steer me in the right direction? Some of the surface mounted component parts...
                          10-29-2024, 03:15 PM
