Tell me if this is glue, I don't think so
  • Bishop
    • Apr 2009
    • 99
    I was brought a Zomodo DVR box to see if I could fix it for a friend. He forgot to bring the power supply, but I opened it anyway.
    It looks like the thing exploded.
    What do you think?
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Tell me if this is glue, I don't think so
    its glue to hold the crystal down.
    • Bishop
      • Apr 2009
      • 99
      I like the sound of that. He said it doesn't fire up, but I to wait till Monday to get the power supply.
      The spec says it needs a 12v 3A supply, but the only 12v I have in stock is just 500ma, 400ma, 300ma and a 200ma.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        power supply is the top suspect.
        • junktv
          • Nov 2010
          • 3065
          I took a molex connector and put a female jack on it. Then made a pig tail with 2 male ends and use my pc to power my router. Was cheaper than buying a wall wart. Local radio shack had all the parts.
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            i have a dozen or more cables made up with a fuse block right to my 12v buss to the solar battery bank.the dvr,cameras,router,and cable modem run right off this.its all on an infinite ups.
            items i keep are selected to work on a loosly regulated 12v source.
            10-16v without issues.put a 1tb laptop hdd in the dvr since the 12v line is right off the incoming power.they only need 5v.
              • 31281
              i get 4a 12v psu's from written-off tv's & monitors.
              • Bishop
                • Apr 2009
                • 99
                Got the power supply today, the HD is toasted.
                Thanks to all
                  by sam_sam_sam
                  03-31-2024, 02:12 PM
                • hikomalek
                  SYMSI70 gas heater, TOP247Y exploded, power supply, snubber network
                  by hikomalek
                  Hello, I have a SYMSI70 gas heater board, which has issues with its primary side power supply, controlled by TOP247Y chip.
                  When I replace a TOP247Y it explode in 1 second. I have desoldered transformer and measured a winding ratio, so transformer looks like OK.
                  Transformer:
                  |Info| Primary | Aux | AB | CD|
                  |Ratio|1|25|40|12|
                  |Voltage AC|230V|9.2V|5.8V|19V|
                  |Voltage DC (*1.41)|230V|13V|8.1V|27V|
                  I have disabled a undervoltage protection of TOP247Y, disconnected secondaries and tried to power it up...
                  09-19-2025, 03:30 AM
                  by sam_sam_sam
                  07-01-2024, 06:34 AM
                • shamsudeen
                  Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                  by shamsudeen
                  Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                  I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                  i know that in linear power supply the noise will be very low comparing to SMPS supply....
                  07-19-2025, 07:14 AM
