KZG - KZJ - Same Electrolyte
  • mockingbird
    replied
    Re: KZG - KZJ - Same Electrolyte
    I have no idea at all whatsoever what they put in the electrolyte, but let me hypothesize that they need to put some sort of chelated metal in it, and instead of using a more expensive alloy, they use iron
  • PCBONEZ
    replied
    No, it's just the particular electrolyte used in KZG and KZJ is crap.
  • Rulycat
    replied
    What's going on at UCC? Were they having manufacturing issues?
  • enduser
    replied
    Originally posted by linuxguru
    Lower ESR and higher ripple current usually means more water in the aqueous electrolyte. It may fail even quicker than KZG under thermal stress. What's the rated endurance of KZJ? If it's 2000 hours or lower, I'd suggest giving them a pass and sticking with Rubycon MCZ or Panasonic FM, both proven workhorses. Maybe even Nichicon HE/HD/HM.
    I just Goggled the KZG series and this post came up. Wow you are right on the money with your prediction. A little over two years from this post, both the KZG and KZJ failed on a Dell Mobo. What is interesting is that the Mobo only had one of each and they were the only ones that failed. No other caps are faulty. It looks like United Chemi-con has now discontinued both those series.
  • yanz
    replied
    if kzj is almost the same with kzg, then people should avoid using it..
  • PCBONEZ
    replied
    I know that. - It wasn't a question it was a warning.
    Been seeing people look for KZJ lately.
    MBZ, MBZ, KZG, KZJ all have the same 2000hr Endurance.
    Also all have same -40C, which suggests about the same water content.
    Whatever the difference is, those aren't it.
  • linuxguru
    replied
  • PCBONEZ
    started a topic KZG - KZJ - Same Electrolyte
    I found this snippet in Chemicon's KZJ datasheet.
    The KZJ series is a new ultra low impedance series from United Chemi-Con. These capacitors are different from the standard low impedance capacitors, as they use a new low resistivity electrolyte. Compared to our KZG series that also uses this advanced electrolyte technology, the KZJ series has lower ESR/impedance and higher ripple current capability, making them ideal for use in computer motherboard circuits where very low impedance at high frequencies is required.
    KZG don't like heat.
    KZJ may turn out to have the same problem.
  • triplefour
    JVC LT-55UE76 has bulged cap on power supply, spilled electrolyte.
    by triplefour
    got this tv from a friend who got a new one and didnt want to bother repairing this one.
    he said it sometimes would just flash color patterns.
    and sometimes it would just work
    i figured it had some intermittent mainboard issue.
    i stored it at home for a while before looking at it
    when i plugged it in for the first time, i heard some popping noises
    and then a big cloud of white smoke came out of the back of the tv!
    i noticed the smoke didnt actually smell like anything. not like when an IC blows.
    i unplugged it and took the back off and discovered...
    12-18-2022, 12:38 AM
  • bajdik
    Lenovo ThinkPad OCP and impedance of Intel i7-10750H
    by bajdik
    Hello, I would like to know if reading of 1.6 OHM on i7-10750H is too low or not.
    I can not compare - no other board with 10th GEN for measurement.
    Thank you very much for your help.
    08-09-2024, 03:38 AM
  • valente222
    HP 14 LA-A993P REV 1.0, identify ic? and not susp# present
    by valente222
    I have a Mb LA-A993P REV 1.0 computer, I am guiding myself with these two shared boards. ;
    there are some ICs that are not the same, in this case those of the PU1501 (JD4TB) and PUH1 (NF4SA) images.
    n, please identify.
    330mA of consumption after 8 seconds turns off. +3VALW AND +5VALW present, EC_RSMRST# , LID_SW# , EC_ON# , ACIN# present.
    SUSP# NOT PRESENT, which would be this the problem does not turn on sub-sources Any leakage?
    I also notice that in the PLH2 coil that belongs to +1.05VS according to the drawings I am not sure,
    06-27-2024, 06:11 PM
  • clearchris
    "Low Impedance" vs "Low ESR"
    by clearchris
    From my research, "low impedance" are pretty much the same as "low esr" caps except the "low esr" caps come in a smaller package. Am I reading this wrong? "Low impedance" caps seem to be much more commonly available (and cheaper) than "low esr" caps. I'm not afraid to lean over some caps if I have to make them fit because of size.
    I'm about to pull the trigger on a pretty large cap order (for me) and want to make sure I'm not buying the wrong stuff. I'm stuck in the house, busy working through my electronics projects, and it would...
    03-26-2020, 09:12 AM
  • SwedishDiesel
    Panasonic caps - dried electrolyte on leads/bung from factory?
    by SwedishDiesel
    I just bought these from Mouser and upon closer inspection the area where the bung and leads meet has some dried green substance on it, presumably dried electrolyte. Is this normal?...
    03-03-2022, 06:06 PM
