KZG - KZJ - Same Electrolyte
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    I found this snippet in Chemicon's KZJ datasheet.
    The KZJ series is a new ultra low impedance series from United Chemi-Con. These capacitors are different from the standard low impedance capacitors, as they use a new low resistivity electrolyte. Compared to our KZG series that also uses this advanced electrolyte technology, the KZJ series has lower ESR/impedance and higher ripple current capability, making them ideal for use in computer motherboard circuits where very low impedance at high frequencies is required.
    KZG don't like heat.
    KZJ may turn out to have the same problem.
    Mann-Made Global Warming.
    - Dr Seuss
  • linuxguru
    • Apr 2005
    • 1564
    Re: KZG - KZJ - Same Electrolyte
    Lower ESR and higher ripple current usually means more water in the aqueous electrolyte. It may fail even quicker than KZG under thermal stress. What's the rated endurance of KZJ? If it's 2000 hours or lower, I'd suggest giving them a pass and sticking with Rubycon MCZ or Panasonic FM, both proven workhorses. Maybe even Nichicon HE/HD/HM.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      I know that. - It wasn't a question it was a warning.
      Been seeing people look for KZJ lately.
      MBZ, MBZ, KZG, KZJ all have the same 2000hr Endurance.
      Also all have same -40C, which suggests about the same water content.
      Whatever the difference is, those aren't it.
      - Dr Seuss
      • yanz
        • Nov 2004
        • 910
        if kzj is almost the same with kzg, then people should avoid using it..
        • enduser
          • Mar 2010
          • 15
          I just Goggled the KZG series and this post came up. Wow you are right on the money with your prediction. A little over two years from this post, both the KZG and KZJ failed on a Dell Mobo. What is interesting is that the Mobo only had one of each and they were the only ones that failed. No other caps are faulty. It looks like United Chemi-con has now discontinued both those series.
          • Rulycat
            • Apr 2010
            • 724
            What's going on at UCC? Were they having manufacturing issues?
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              No, it's just the particular electrolyte used in KZG and KZJ is crap.
              - Dr Seuss
              • mockingbird
                • Dec 2008
                • 5488
                I have no idea at all whatsoever what they put in the electrolyte, but let me hypothesize that they need to put some sort of chelated metal in it, and instead of using a more expensive alloy, they use iron
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  It's some kind of Aluminum solution because the foil it is 'electrolyticing' with is Aluminum.
                  I think they made a bad choice in one of their stabilizer additives and the electrolyte simply breaks down.
                  - Dr Seuss
                  • mockingbird
                    • Dec 2008
                    • 5488
                    I wonder how gold would factor in with capacitor electrolyte. Is it possible to create really high quality stuff with it? It is a highly conductive metal and it doesn't oxidize, unless you throw it in highly concentrated sulphuric acid.
                    • Pyr0Beast
                      • Feb 2009
                      • 406
                      You have silver mica capacitors.
                      But ordinary lytics need to oxidise to work properly. Aluminium oxide works as an insulator.
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        In Aluminum Electrolytics the Aluminum Oxide layer -IS- the Dielectric.
                        The separator paper is only in there to act as a carrier [flow path sort'a] so the electrolyte can get to the Aluminum to keep it oxidized.
                        Ripple currents blast chunks [figuratively] of the Oxide [or Aluminum depending on instantaneous polarity] into solution where it disolves.
                        The DC voltage present restores the damaged areas similar to how electroplating works.
                        - That's why electrolytics used to be called 'self healing capacitors', although the term has fallen out of use over the years.
                        - Dr Seuss
                        • mockingbird
                          • Dec 2008
                          • 5488
                          Interesting. But if this is the case, why do capacitors instantaneously provide their rating, if it took voltage to "stimulate" them, wouldn't you have to wait a minute or two for the voltage to do it's work?
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            You lost me.. ??
                            ""instantaneously provide their rating"" ??
                            What which rating??
                            - Dr Seuss
                            • mockingbird
                              • Dec 2008
                              • 5488
                              ... You said that the electrolyte oxidizes the aluminium when DC voltage is applied, and when it ceases, it "self heals". Surely this process would take a minute or two, so when the current is initially applied, the capacitance would be significantly out of spec?
                              • Pyr0Beast
                                • Feb 2009
                                • 406
                                Nope. Oxide layer does not dissolve that easily.
                                Old caps that have gathered dust for past 5 years, yes. They need to be regenerated.
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  No, misinterpretation,,,
                                  Ripple damages the -existing- oxide layer and the DC repairs the damage.
                                  - Bear in mind the ripple is in mV and the DC is in Volts. Small local damaged areas, big global [so to speak] healing.
                                  - Also once the oxide layer gets to a certain thickness [based on the applied DC] the healing will stop because the oxide layer is an insulator.
                                  - Also a thin area [damaged] of the oxide layer will get the most healing effect simply because the insulation is thinner there.
                                  The aluminum foil is etched and pre-oxidized to some extent [usually chemically] before the foil pack is rolled.
                                  Then they use a process called 'forming' to build up the oxide layer.
                                  Forming is basically applying DC at a low voltage then slowing increasing it to build up the oxide layer's thickness to what it should be for the rated voltage.
                                  In other words caps come from the factory with an oxide layer.
                                  The oxide layer doesn get thinner with no DC applied but it takes years.
                                  -The oxide dissolving back into the electrolyte on unused caps is one major things [if not THE major thing] that determines shelf-life.
                                  That's why they recommend 're-forming' old caps before use.
                                  - Dr Seuss
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    Yeah,,, what he said...
                                    - Dr Seuss
                                    • Pyr0Beast
                                      • Feb 2009
                                      • 406
                                      I doubt that ripple would eat oxide layer. That wouldn't happen as long as cap doesn't go into reverse polarity.
                                      • PCBONEZ
                                        Grumpy Old Fart
                                        • Aug 2005
                                        • 10661
                                        Ripple DOES go in reverse polarity.
                                        It is a small AC ridding on a DC.
                                        If you think it won't eat the layer stick a DC [polarized] cap on AC with no DC and tell me what happens.
                                        - Dr Seuss
                                        • triplefour
                                          JVC LT-55UE76 has bulged cap on power supply, spilled electrolyte.
                                          by triplefour
                                          got this tv from a friend who got a new one and didnt want to bother repairing this one.
                                          he said it sometimes would just flash color patterns.
                                          and sometimes it would just work
                                          i figured it had some intermittent mainboard issue.
                                          i stored it at home for a while before looking at it
                                          when i plugged it in for the first time, i heard some popping noises
                                          and then a big cloud of white smoke came out of the back of the tv!
                                          i noticed the smoke didnt actually smell like anything. not like when an IC blows.
                                          i unplugged it and took the back off and discovered...
                                          12-18-2022, 12:38 AM
                                        • bajdik
                                          Lenovo ThinkPad OCP and impedance of Intel i7-10750H
                                          by bajdik
                                          Hello, I would like to know if reading of 1.6 OHM on i7-10750H is too low or not.
                                          I can not compare - no other board with 10th GEN for measurement.
                                          Thank you very much for your help.
                                          08-09-2024, 03:38 AM
                                        • valente222
                                          HP 14 LA-A993P REV 1.0, identify ic? and not susp# present
                                          by valente222
                                          I have a Mb LA-A993P REV 1.0 computer, I am guiding myself with these two shared boards. ;
                                          there are some ICs that are not the same, in this case those of the PU1501 (JD4TB) and PUH1 (NF4SA) images.
                                          n, please identify.
                                          330mA of consumption after 8 seconds turns off. +3VALW AND +5VALW present, EC_RSMRST# , LID_SW# , EC_ON# , ACIN# present.
                                          SUSP# NOT PRESENT, which would be this the problem does not turn on sub-sources Any leakage?
                                          I also notice that in the PLH2 coil that belongs to +1.05VS according to the drawings I am not sure,
                                          06-27-2024, 06:11 PM
                                        • clearchris
                                          "Low Impedance" vs "Low ESR"
                                          by clearchris
                                          From my research, "low impedance" are pretty much the same as "low esr" caps except the "low esr" caps come in a smaller package. Am I reading this wrong? "Low impedance" caps seem to be much more commonly available (and cheaper) than "low esr" caps. I'm not afraid to lean over some caps if I have to make them fit because of size.
                                          I'm about to pull the trigger on a pretty large cap order (for me) and want to make sure I'm not buying the wrong stuff. I'm stuck in the house, busy working through my electronics projects, and it would...
                                          03-26-2020, 09:12 AM
                                        • SwedishDiesel
                                          Panasonic caps - dried electrolyte on leads/bung from factory?
                                          by SwedishDiesel
                                          I just bought these from Mouser and upon closer inspection the area where the bung and leads meet has some dried green substance on it, presumably dried electrolyte. Is this normal?...
                                          03-03-2022, 06:06 PM
