"Low Impedance" vs "Low ESR"
  • clearchris
    • Dec 2013
    • 687
    From my research, "low impedance" are pretty much the same as "low esr" caps except the "low esr" caps come in a smaller package. Am I reading this wrong? "Low impedance" caps seem to be much more commonly available (and cheaper) than "low esr" caps. I'm not afraid to lean over some caps if I have to make them fit because of size.
    I'm about to pull the trigger on a pretty large cap order (for me) and want to make sure I'm not buying the wrong stuff. I'm stuck in the house, busy working through my electronics projects, and it would be nice to not have to order caps on a project by project basis.
    Edit: Also, are there any nichicon series caps that are best avoided? They seem to be the most competitive "good manufacturer" caps in the "low impedance" space.
    Re: "Low Impedance" vs "Low ESR"
    Look at table 2.
    • clearchris
      • Dec 2013
      • 687
      According to that table, if I am reading it right, is that "low impedance" caps(Low Z) have lower ESR and higher ripple current tolerance. So that makes "low impedance" caps better than low ESR?
      Edit: Or maybe the answer is: depends on the capacitor. A "low ESR" designation might not mean anything.
      • Curious.George
        • Nov 2011
        • 2305
        • Unknown
        An ideal capacitor (which only exists "in theory") has no resistive component. It is a perfect energy storage component; everything that goes in (can) eventually come back out.
        In practice, a capacitor is an ideal capacitor with several other "parasitic" characteristics that alter its behavior from the ideal.
        E.g., the fact that a capacitor can't hold a charge indefinitely implies that there is some "load" across the capacitor that is bleeding off (consuming) that charge.
        Similarly, the fact that a capacitor can't absorb all of the charge pushed into it implies that there is something "consuming" some of the charge as it tries to get INTO the (ideal) capacitor -- i.e., in series with that ideal capacitor.
        Both represent "losses". But, they have different consequences to the circuit in which they reside.
        A high(er) ESR means the ideal capacitance is less coupled to the circuit node to which it is attached -- changes at it's input are NOT absorbed by the capacitance as well as they could be.
        A low(er) parallel (leakage) capacitance means the cap holds its charge for less time than ideal.
        This is why you will often see multiple capacitors "in parallel" instead of a single LARGER capacitor -- the behavior of the GROUP of smaller caps is better (in some regard) than that of a single larger cap.
        [The ESRs of each of the small caps look like they are in parallel with each other so the EFFECTIVE resistance is much smaller]
        Note that even these parasitic elements are dynamic, in nature. A cap can perform "well" at one frequency and poorly at another (caps a physical devices so how they are built has an impact on how they perform)
          by momaka
          03-12-2025, 03:42 PM
        • eryjus
          by eryjus
          05-10-2023, 11:21 AM
        • captain150
          by captain150
          03-16-2025, 07:34 PM
        • madscientist750
          Replacing electrolytic caps by solid caps on old motherboards
          by madscientist750
          I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
          I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
          I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
          10-19-2025, 06:10 AM
        • black6host
          Replacement caps for Samson Resolv studio monitor 65A Amp board.
          by black6host
          Good day!
          I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
          I'm going to replace the caps and I'll be the first...
          02-06-2024, 08:22 PM
