Bought some capacitors but not sure if they are worth using
  • fickit1time
    • Apr 2014
    • 13
    • canada
    I have a couple power supplies and TV's I'd like to get working again.
    So I went ahead and bought some capacitors from ebay, from the same ebay store as well.
    I didn't realize you guys have a store until I read some other threads.
    I used a capacitor reading to get the values and it seems out of the 40 caps, only 13 of them meet their specified values
    I'd like your opinion on whether these are acceptable or do I have cause to open a case with ebay to return these caps.
    10pcs - 560uF 35V 10x16mm Panasonic FR Low ESR 35V560uF Audio grade Capacitor
    555 uF
    544 uF
    542 uF
    528 uF
    508 uF
    497 uF
    489 uF
    484 uF
    485 uF
    475 uF
    5pcs - 1000uF 35V Nichicon VR 13x20mm 35V1000uF Electrolytic Capacitor
    1100 uF
    1091 uF
    1068 uF
    1054 uF
    1016 uF
    10pcs -2200uF 16V Japan ELNA RE3 10x20mm 16V2200uF Audio Capacitor
    2300 uF
    2270 uF
    2240 uF
    2240 uF
    2190 uF
    2190 uF
    2150 uF
    2150 uF
    2130 uF
    2040 uF
    10pcs -16V 3300uF 16V Japan ELNA RE3 10x30mm Audio Capacitor
    3280 uF
    3240 uF
    3230 uF
    3230 uF
    3220 uF
    3220 uF
    3210 uF
    3210 uF
    3190 uF
    3130 uF
    5pcs -3900uF 25V 12.5x30mm 25V3900UF Japan ELNA top grade Audio Capacitor
    4170 uF
    4116 uF
    4110 uF
    4110 uF
    3570 uF
    • 31214
    Re: Bought some capacitors but not sure if they are worth using
    the 560uf FR's are fake - the vent shoult NOT look like a cross.
    the print's wrong anyway.
    • retiredcaps
      • Apr 2010
      • 9271
      As stj mentioned, the Panasonic FR are fake. They should have a "T" like vent.
      The Nichicon's and ELNS's are rated at 85C. In a TV and power supply, you want 105C so they last longer.
      In your last picture, the ELNA cap has an extra lead sticking out?
      Overall, looking at your purchases, they look like fake/counterfeit and poor overall.
      Buy your caps from a reputable distributor like digikey or mouser. Avoid Ebay and aliepxress.
      Additionally, when buying low ESR caps like a Panasonic FR, it is the ESR value that is more important than the capacitance value. Capacitance value can be +/- 20% of its stated value.
      --- begin sig file ---
      --- end sig file ---
      • fickit1time
        • Apr 2014
        • 13
        • canada
        Thanks very much guys.
        I will open a dispute with ebay.
        The ELNA cap is a audio capacitor, I shouldn't have bought that one so i'm assuming that is the reason for the extra lead.
        I only realized you guys had a store today so I'll like buy from your store instead.
        • Mint Waxed
          • Aug 2016
          • 35
          555 uF
          544 uF
          542 uF
          528 uF
          508 uF
          497 uF
          489 uF
          484 uF
          485 uF
          475 uF
          1100 uF
          1091 uF
          1068 uF
          1054 uF
          1016 uF
          2300 uF
          2270 uF
          2240 uF
          2240 uF
          2190 uF
          2190 uF
          2150 uF
          2150 uF
          2130 uF
          2040 uF
          3280 uF
          3240 uF
          3230 uF
          3230 uF
          3220 uF
          3220 uF
          3210 uF
          3210 uF
          3190 uF
          3130 uF
          4170 uF
          4116 uF
          4110 uF
          4110 uF
          3570 uF
          I'll throw my 2-cents worth into the discussion. In my opinion, buying electronic parts off eBay is kind of risky business. You have no idea where they were made and if knock offs or their age. My best suggestion is to take a look at MouserElectronics and into the search box type: electrolytic capacitors, leaded. You might pay a few cents more per unit but I've never gotten junk from Mouser. You can also buy in higher quantities than single units to get a price break.
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            the elnas look real.
            the rest are fakes.
            its no surprise since you bought them on fakebay.
              I bought three of these Sparkle Power FSP460-60GLC - Computer Power Supply 460Watts recap need
              by sam_sam_sam
              I have bought computer switching power supplies from Electronic Goldmine before and every one of them the capacitors were bloated and or leaking out of the capacitors so I am sure that these are going to be the same way five or six years ago I had bought some 300 and 350 watt computer switching power supply from Electronic Goldmine these are all from FSP brand
              Here is the listing for this switching power supply they only had three of them in stock and I bought all three of them
              https://theelectronicgoldmine.com/products/g28149
              I have one old computer that...
              07-18-2024, 06:55 PM
            • Ady2017
              Are there any datasheets available for Elna RJG capacitors?
              by Ady2017
              I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
              05-25-2025, 02:19 PM
              Another project idea for a battery bought from Battery Hookup with a good BMS board
              by sam_sam_sam
              https://batteryhookup.com/products/n...-2900mah-cells
              One note these battery packs are below 10 volts and the BMS protection board has locked them off from having any voltage on the BMS output wires I have tested three of them so far and voltage is around 8 volts it not an issue because it testing about 9.2 amp hours
              The price of this offer has gone up sense I bought these two boxes
              I bought two boxes of these batteries but there is a catch to the these battery packs
              The BMS protection board does work but it...
              07-31-2022, 04:07 AM
            • xnRS
              Did I just bought a fakecap ?
              by xnRS
              Today I bought... I mean friend of mine bought capacitors that I ordered, as the shop where i bought it is too far away from me, as he isn't understands anything in electronics, he just bought it as I ordered. At first shop on their page showed 1800uf 6.3V Sanyo caps, with generic picture and code SY-1800(which isn't correct). After little bit of search I found out that it was WG 8X20 capacitors(p.s found that out before buy). Ok, ordered, next day friend gives me package with those caps and some other caps that I ordered. But... This were NOT the Sanyo WG, these were Panasonic(Matsushita) FL...
              06-01-2021, 07:48 AM
              I just bought a SkyRc MC3000 battery testing machine very interesting device temp
              by sam_sam_sam
              I just bought this device that came in the mail today I put a set of 4 brand new 21700 high current battery on the charger
              The charger has four individual temperature sensors for each battery cell
              The bar graph for each individual battery cell is very primitive but will give you a good idea of how each battery cell is preforming and I find something odd I put on the individual battery testing machine that gives more details of the charging/discharging curves but it will be quicker to just charge and discharge battery cells that do not have any issues
              Or test...
              09-14-2022, 07:12 PM
