Replacement capacitors wanted - Where can I get them?
  • peterpan783
    • Jan 2004
    I'm in England and I need to know where I could buy good replacement low ESR capacitors to repair quite a few dead motherboards I have.
    They all show the typical symptom of capacitor failure: bulged and/or leaking capacitors. Some others do not show apparently broken capacitors, but fail to power up as well.
    Where could I get them? What makes/brands would be available here?
    Could you please reply soon?
    ThanX
    Posted by Peter Pan :-)
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    www.digikey.com will ship internationally. They have Panasonic FC serioes, which are excellent caps. They're a bit pricey, but will have what you need.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      RS components UK for Panasonic FC
      http://rswww.com/
      Farnell UK for Rubycon ZL
      http://uk.farnell.com
      these are the obvious ones. if you find others let us know
      • groomit
        Google Pixel 5 - Proximity Sensor Issues - Reflow/Replacement procedure tipps wanted
        by groomit
        I just replaced the battery on a Google Pixel 5.
        After that the proximity sensor isn't functioning properly any more. It is constantly activated. So when playing a voice message on Whatsapp, the Screen instantly turns off.
        Checking with a sensor app I can verify weird behavior of the sensor. It is triggered when nothing is near and sometimes works correctly when squeezing the phone next to the sensor hole.
        The rubber seal is on again (as mentioned in various suggestions in other forums).
        This smells like a cold or broken solder joint. So I'd like to reflow...
        06-11-2025, 02:21 AM
      • slybunda
        AA and AAA battery charger capacitors?
        by slybunda
        hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
        it has inside:
        2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
        2 x 470uf 16v LZ105c branded as G.Luxon
        not heard of these brands are they any good?
        iv attached photos of the charger and the board inside for an idea on the type of...
        12-24-2023, 04:41 AM
        After all of...
        07-13-2024, 08:14 PM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • the_rem
        Unknown transformer : how to find a good replacement part ?
        by the_rem
        Hello guys,
        I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
        I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
        04-23-2025, 01:48 AM
