I agree 100%.
Well, this is less likely to happen to the CPU VRM, since it usually has a more advanced chip than your typical PWM controller. But I agree that capacitors on the input of a buck regulator indeed should not be deemed less important than the output.
As you know (I'm sure I mentioned it more than once
), I've had a router die from bad caps on its buck regulator input. And that's just once instance off the top of my head. Had a few other similar cases in other devices.
