Recapping for the first time
  • 370forlife
    Large Marge
    • Aug 2008
    • 3113
    I am going to order a recapping kit for my VP6 and finally get to using this thing. But, I don't want to ruin this board in the process. Is recapping as hard as it sounds? I can get a few old motherboards I can practice on (maybe unsolder some caps from two motherboards of the same uf and voltage, and switch them around....) idk, get some practice in and see if i'm any good at it. I have a friend that can do it, he won't charge me, but I want to get good at doing it myself.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Recapping for the first time
    yes practice on trash till you get good at it.
    the vp6 is not difficult to recap.
    easy for me to say after doing several hundred ;-)
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      definitely practice.
      add new solder to the existing before you remove the caps or you are going nowhere fast
      use a 60-80w iron with chisel tip 450oC.
      the most important part is to be comfortable. damages happen when you are not paying attention and the iron slips or you are tired or you rush cos you are finishing
      if you are getting nowhere with the removal or clearing the holes then you should modify the technique. dont persist with the same technique until your hand is tired because the board is now dead probably
      be careful of traces right next to the cap hole. that is where you dont want to heat for looong time.
      if you are clearing with a needle and getting nowhere then add solder to the other side and try there too.
      your first board would be a day job for the weekend not when a few hours are remaining in the evening.
      its not difficult. older boards are easiest
      • yanz
        • Nov 2004
        • 910
        agree on that..
        • Super Nade
          • Jun 2006
          • 294
          Absolutely..old boards are very nice to recap...
          Also as willa says, add a gob of solder before you attempt to remove the cap or you will have a nice burn on the PCB.
          Q6700 @ 3.6 GHz
          Zippy GSM-6600P
          Curcial Ballistix PC6400 (4 x 1Gb) Micron D9GMH
          Abit IP35Pro
          ATi HD4870
          • Newbie2
            • Sep 2005
            • 885
            Agree!
            Also, working on an older motherboard is much easier than the newer ones. My soldering iron's tip is a 375c tip, which isn't hot enough for the newer motherboards. On an older motherboard, with a little patience and time I can recap it. On a newer motherboard (P4 and newer), it is almost impossible for me to recap it without getting something totally messed up, to the point that I have to put out my drill to drill through the holes.
            My gaming PC:
            AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
            ASUS M4A77TD AMD 770 AM3 Motherboard
            PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
            G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
            TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
            WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
            ASUS Xonar DG 5.1 Channel PCI sound card
            Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
            Antec Three Hundred Mid-Tower Case
            Microsoft Windows 10 Pro 64-bit
            Microsoft Windows 7 Ultimate SP1 64-bit
            • titomno2
              Gaming Laptop Zephyrus S17 TFT not detected every time !
              by titomno2
              Hi guys,
              I post my problem here because I think it could be a capacitor related issue (Asus support on this particular subject is non-existing).
              So the computer is a Zephyrus-S17-GX735LXS-26T and the strange behavior is seen.
              On cold start most of the time the internal screen is detected and a picture it works fine until shutdown, sleep or deep sleep.
              Then the screen won't work for a long period of time.
              If I wait 1 or 2 hours it work again most of the time.
              When it doesn't work the batterie indicator blink 3 times white stop and the same schematic is repeated...
              01-19-2025, 08:27 AM
            • kokodin
              windows 10 embeded key on a desktop motherboard - inventory issue
              by kokodin
              Hello, a bit silly question here.
              I work at a school. we have IT class for computer assembling in a technical highschool and we kind of need more hardware for practicing.
              Computers we bought in 2019 had unsuficient motherboards for our regular clases so they were replaced before going online with computers for the first time and licences transfered to new motherboards. they are "windows pro for school" so as a school we are allowed to do that, we just can't have 2 computers with the same licence. So i have a stockpile of unused motherboards. Now that cpu's for them are a...
              02-06-2025, 02:35 AM
            • flat-earther
              Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
              by flat-earther
              I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
              To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
              I have opened the camera and I think there is enough room to add something inside to accomplish this:
              The camera is powered by a 3.7V nominal single cell lithium ion battery.
              So I need to connect another battery in...
              06-08-2025, 02:00 AM
            • keldeo
              Obscure Pentium laptop, sudden short?
              by keldeo
              I've purchased this weird (and might add appears to have had a fairly rough life) laptop a while ago for $1 at a yard sale. It powered up one time, (saw a POST screen!) Then, never powered again. I've since thrown it in some dark corner, BUT, I've decided to look at it again. First, this seems like a very obscure laptop, mine just has the name "BIT" on it and nothing else. Very similar (same?) can be seen here https://www.vogons.org/viewtopic.php?t=54655.
              At first, I had gotten the weird mini display on the lower part of the laptop to display a few icons, but if I attempted...
              01-02-2025, 03:22 AM
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
