ESR confusion, what is good and bad esr
  • odgaf
    • Apr 2015
    • 36
    im confused over esr ratings, if i have a cap that should have an esr of 0.6, but it has an esr of 0.20, is that cap good or bad, how far out of spec can esr go before a cap is bad,
    also if i have a cap thats esr is supposed to be 0.20, but shows as 0.1, would this cap be ok and if not why
  • mariushm
    • May 2011
    • 3799
    Re: ESR confusion, what is good and bad esr
    It depends on the volume of the capacitor and the capacitance.
    A 10uF 400v capacitor could have an esr of 0.6-2 ohm and it would be OK, because it's a small capacitor both in value and capacitance.
    A 270-470uF 400-450v primary capacitor could have an esr of around 0.4-0.8 ohm and it would be acceptable.
    However, from a larger volume capacitor like a 2200-3300uF capacitor rated for 6.3-16v, low esr would be considered a value under 0.1 ohm
    With some experience you get used to what to expect from various capacitance/voltage combinations.
    For computer switching power supplies and power supplies in monitors, which usually run at high frequencies (something like 40-150 kHz), you can just look up the impedance at 100 kHz column in datasheets of various capacitors to know in what range the esr should be for that capacitor.
    At 100kHz or around that frequency, impedance is pretty much the same as the esr value.
    • odgaf
      • Apr 2015
      • 36
      hi buddy thx for helping, im a complete noob at this
      i get that the esr depends on capacitance, but on a 220uf 16v caspacitor rated at an esr of 0.3 im getting a reading of 0.30, im using a peak esr 70 to take the measurement, and im unsure at what point a caps esr is defective ?
        • 31288
        0.3 = 0.30
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          Originally posted by stj
          0.3 = 0.30
          But are you sure?
          @ odgaf: like stj said, 0.3 is the same as 0.30. So you cap is in spec. Also 0.6 (i.e. same as 0.60) is more than 0.20. So your caps appear to be in spec... or at least from what you give us from your spec vs. measurement values.
          • Mint Waxed
            • Aug 2016
            • 35
            To start, I think a definition of ESR would be useful for those who might not know. "ESR is the sum of in-phase AC resistance. It includes resistance of the dielectric, plate material, electrolytic solution, and terminal leads at a particular frequency. ESR acts like a resistor in series with a capacitor (thus the name Equivalent Series Resistance)". A very informative (pdf) article by Mark Gebbia can be found at this link:
            • PeteS in CA
              • Aug 2005
              • 3583
              • USA, Unsure of Planet
              When an electronics teacher or professor tells students, "Assume an ideal capacitor," ESR is one of several real-world things he's telling students to ignore. In that sense, ESR is an imperfection, but always present to some degree.
              ESR was defined well by "Mint", above, except that ESR does not include the resistance of the dielectric, which should be as close to infinite as possible. Being a resistance, Ohm's Law applies, and if - as in the case of a P/S or VRM O/P cap - the cap is conducting significant AC current (aka "ripple current") power is dissipated (which hurts efficiency), and heat is generated (which can accelerate electrolyte evaporation). Basically, there is no such thing as "good", i.e. desirable, ESR.
              In the real world, if the ESR of a cap is higher than its datasheet rating, it's either gone bad, or was never good. In that same real world, a control circuit, such as in a P/S, has design elements that compensate for the effects of ESR in that control loop. If the ESR is too high or too low it will cause performance problems and/or instability in the control loop.
              So, in the context of an entire circuit design, it is possible for ESR to be too low. This is the reason, in many threads here, there is frequent discussion about whether a particular series cap is a suitable replacement for a cap of another series. The replacement needs to have specs similar to those of the original(s).
              HTH
              PeteS in CA
              • MORETTIGIAN
                Capacitor detached from PCB – RTX 2070 Super Founders Edition
                by MORETTIGIAN
                Title:
                Description:
                During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                I did not notice it detaching, so I am unsure of its original location on the PCB.
                Procedure performed:
                - Removed backplate
                - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                - Reapplied thermal compound
                - Reassembled card
                Observed behavior after reassembly:
                - GPU powers on and operates normally under...
                09-18-2025, 12:14 PM
              • cook
                Good brands of run capacitor for house heat hump
                by cook
                Are there good brands for 'run capacitors' or 'start capacitors' that are used on electric motors or heat pump compressors? ... r are the good capacitor brands for electronics (power supplies, laptops, motherboards, etc.) also the good brands for run capacitors?
                Yeah I know this might be a novice question, but I just wanted to be sure. I did do a search on the forum but did not see this question asked before.
                09-13-2024, 12:53 PM
              • Prolog
                RTX 3080 FE Identifying capacitor
                by Prolog
                Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                I hope these photos make it clear which component I am referring to:
                (yes, the soldering is a bit botched from removing the blown one, I know)
                I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                12-01-2024, 08:27 PM
              • Sparklingx
                SMD ceramic capacitor capacitance & voltage
                by Sparklingx
                what is the easiest way to measure the capacitance of SMD ceramic capacitors and its rated voltage?...
                09-12-2024, 01:04 AM
              • Loretto
                Samsung SMPS BN44-00339A
                by Loretto
                this unit comes from a samsumg LCD TV LE32C530F1W which stopped working after making a strong noise like something was exploded inside of it.
                I opened it and found that fuse FP801S was blown, capacitor CP814 was completely disintegrated and MOSFET QP801S was shorted.
                I replaced all of them and instead of the fuse I connected a 100 Watt bulb. Then, without connecting it to other TV boards, I switched it on, but the bulb begun to blink.
                I thought that maybe the bulb was somehow interfering with the normal operation of the power supply, so I replaced it with a fuse,...
                03-29-2025, 08:30 AM
