Fake Nichicons
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Fake Nichicons
    I ended up getting a whole batch of fake Nichicons. I recently found out there were at least 4 different manufacturers thrown into the batch of fakes based on the bungs and the top patterns. I think one of the fake sources is Teapo (three lines and dots) but the others have a simple cross on the top vent.
    I noticed "type 3" - the third from the left - had no way in hell in surviving anything above about 10 volts. I don't know about the other ones but suspect they all have the same problem. These are all rated 3300uF 16V and a fake RS(M) written on them.
    "Type 4" - the one on the right (or fourth from left) looks like a Teapo but I don't know what Teapo bungs look like for sure. It measured 2200uF so that one's really wrong.
    I got a refund for them (and did not have to return this trash) after pointing it out so I guess I'm not too upset but finding it interesting...
    In the other thread where I bloated/exploded two of them, these were "type 3".
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Fake Nichicons
    Just curious, since you live in the USA, do you buy caps from digikey and/or mouser?
    You are likely to get real genuine parts at reasonable prices.
    --- begin sig file ---
    --- end sig file ---
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      Re: Fake Nichicons
      No this was a China source. I kind of assumed these were phony to begin with but expected them to "work" at least for a short while as I wanted to use them as test caps (like what I did). However these are not even acceptable at all!
      I'm planning to do at least a partial recap (mainly the X caps and a few of the analog PSU filter caps) of my Tektronix 2440 and going to be ordering from Mouser.
      BTW, I noticed my crap NTE capacitors (probably Teapo as well?) look like "Type 4".
      I had a spare "jwco" crap cap and the bung/vent seems to match "Type 2".
        • 31084
        Re: Fake Nichicons
        NTE = any old crap we can find and rebadge that can replace the original - atleast in most applications!.
        ever wonder why they dont have the original markings aswell as the NTE number?
        because if they did, you could get a datasheet and look at the real price!
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Re: Fake Nichicons
          Yeah, I would imagine the vent and the seal bung would still match the original manufacturer. From vague pictures I saw on the web it indeed looks like a Teapo.
          Incidentally I don't know why I haven't come across a blown Teapo yet. Mostly Fuhjyyu's for me.
          I think whoever did these Nichicons are even worse than NTE. At least NTE tried to make it work for some applications. This counterfeiter seems to have made it work for NO applications!
          (though I'd like to try my 470uF 35V NTEs that I have on a PSU to see if I can see the same behavior. Alas my Sencore only has a 25 and then 50V range.)
          • Alex@
            Fake Nichicons?
            by Alex@
            I have recently received some Nichicon LKS1J103MESB 10,000uf 63v capacitors. They felt very light when I picked the up so I decided to weigh them. On my admittedly cheap scales they weigh 46grams the spec sheet says they should be 59grams. I tried them on 3 sets of scales and the readings are the same. The seller says that he only buys from mouser and digikey.
            Is it possible for them to be real Nichicons? I really want them to be genuine it would save much time and effort. I am recapping an old Audio Dynamics ca2000e amplifier (I know it is an obscure make but...
            08-17-2021, 02:38 AM
          • iMic
            IBM NetVista Pentium III - USI Motherboard w/ Teapo SC
            by iMic
            Hi folks,
            I have a couple of IBM NetVista desktop computers from around 2000-2001. They have Universal Scientific Industrial (USI) Pro286i motherboards, 733MHz Pentium III processors, and a whole bunch of bad Teapo capacitors. One board has visibly bad and venting capacitors, while the other doesn't look too bad so far.
            The board with venting caps works fine, while the good looking board occasionally refuses to power on unless it's left for about 30 seconds after connecting the power - even with a known good power supply. (I am however aware I'll need to check the PSU...
            11-29-2023, 06:44 AM
          • paparazzo79
            Fake magsafe 2 charger
            by paparazzo79
            Hi guys.I bought Macbook Pro mid 2014 15 inch model which did not came with charger.
            I got new charger but judging by the specs seems it is fake one.Sadly I live in Bosnia and genuine charger is rare to find.
            what to do?Should I use the fake one?
            Will it damage the macbook?...
            10-02-2024, 08:18 AM
          • Galraedia
            Fake Caps in Xbox 360
            by Galraedia
            I decided to take one of the Rubycon capacitors out of a phat Xbox 360 with a Zephyr motherboard and noticed that all the Rubycon capacitors near the CPU were fake. The capacitors in question are Rubycon MFZ 680uf 6.3V and they all have a bullseye bottom, something not found in genuine Rubycon capacitors. None of them were leaking, they all have the K top, and the system has never been opened before. It appears Microsoft was using fake capacitors in the Xbox 360, or the Chinese facility where the console was manufactured in was using them and passing them off a genuine. Just thought I'd share...
            02-04-2023, 09:55 PM
          • eliemgh
            t470 have fake charging
            by eliemgh
            i have t470 have fake charging...
            09-14-2024, 06:11 AM
