I've just run into this japanese company http://www.uniconcap.co.jp/company.php?id=2&lang=en They are in business since 1965 and even do polymers. Never heard of them before. Experiences?
Unicon any good?
Unicon any good?
Last edited by Behemot; 06-01-2016, 03:57 PM.Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Tags: None -
Re: Unicon any good?
WIMA mostly makes film caps if I am not mistaken, I don't think I've ever seen bad one. CD makes mostly big can caps and special caps, somewhat out of our usual product. I'd use them if they got the neccessary specs for a good price.
But Unicon makes small THT sizes, that's exactly what we use 98% of the time here…Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!Comment
Hmm, according to this company, they are the OEM for Unicon:
http://www.sh-elcon.com/about.html
But should we believe them?Comment
Sometimes where you find those caps can be a decent indicator of the quality you may want to expect.
If you find it in a decent PSU like Enhance for example, I'd expect that they aren't that bad. Just because no one knows a brand doesn't mean that they are bad, it just means that they was a bit on the expansive side or just not that easy to get a hold of...Comment
by irepair559PS4 1215A HDMI DIODE READINGS GOOD EVERYTHING GOOD BUT NO PIC? everything is good! what else can it be? if hdmi diode values are good that means encoder and filters are good right? idk what else it can be guys...01-05-2023, 12:32 AM
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
Thanks-
Channel: BIOS Requests ONLY!
by the_remHello guys,
I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow... -
by cookAre there good brands for 'run capacitors' or 'start capacitors' that are used on electric motors or heat pump compressors? ... r are the good capacitor brands for electronics (power supplies, laptops, motherboards, etc.) also the good brands for run capacitors?
Yeah I know this might be a novice question, but I just wanted to be sure. I did do a search on the forum but did not see this question asked before.
Thanks-
Channel: General Capacitor Questions & Issues
- Loading...
