Replacing Caps on an LED Driver Board
  • Winston Chadwick
    • Mar 2016
    • 34
    I'm converting a 17 inch ELO touchscreen monitor (et1739l-8cwa-3-npb-g) to an LED backlight. The driver board came in a kit with the LED light strips. The two caps on the board appear to be labeled Chang X. I would like the this device to last as long as possible so, I figured I would replace these caps.
    The driver board runs on 12V from the monitor power supply.
    The cap next to the 6-pin monitor power supply connector is labeled 220uF 35V. It is 8mm in diameter and about 12mm tall. Cap must be oriented horizontally across the board to fit in the monitor's back panel, but there is room for a taller cap if it is horizontal. I found a United Chemi-con KZN series with similar specs (220uF 35V EKZN350ELL221MH15D). Would this be a suitable replacement?
    The cap next to the inductor and the LED strip connectors is labeled 22uF 100V. Does this cap really need something with such a high voltage rating? It is 6mm in diameter and 12mm tall. An 8mm diameter would fit, but it would hang off the edge of the board, so I'd like to stick to 6mm if i can. This cap must also be oriented horizontally, and there is room for a taller cap. The only 10000 Hrs @ 105°C cap I could find with similar specs is a Rubycon YXM series 22uF rated for 63V. Unfortunately, the minimum order from Digi-Key is 3000 units. Is there any other cap that would work as a reliable replacement?
    Could I replace these Chang caps with polymer caps? I'm willing to pay more if it means better longevity.
    • 31289
    Re: Replacing Caps on an LED Driver Board
    i dont see why poly's wouldnt work.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      You need to keep the voltage the same, the leds will run at about 60-70v coming off the driver so keep cap voltage the same. Also can you post images of the final repair job ?
      • Winston Chadwick
        • Mar 2016
        • 34
        Thanks, I'll look into those.
        Thanks for the info. I'd be happy to post pics when I'm finished.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Awesome cheers hope it goes well
            • 31289
            22/100 rubycon YXJ looks good.
            • Winston Chadwick
              • Mar 2016
              • 34
              Thanks stj. The YXJ looks like it will work nicely.
              • Winston Chadwick
                • Mar 2016
                • 34
                Sorry for the delay in posting the pics.
                I couldn't find YXJs in the quantity I wanted. I went with a Panasonic FC 22/100 (8mm diameter). I think it fits well enough.
                I used an FM for the 220/35.
                Display brightness controls and backlight on/off work as I had hoped.
                Pics.
                1. Elo back panel with the original inverter for the CCFLs
                2. LED driver installed
                3. LED test
                4. LCD removed
                5. Burnt CCFL
                6. LEDs in lighting rail
                7. Perfect fit
                8. Ready for back panel
                9. Final test (My camera picked up some glare from the glass digitizer)
                • Noodneek
                  Replacing all the caps on the BenQ SW2700pt's power board didn't help...
                  by Noodneek
                  My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
                  I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
                  08-30-2024, 12:52 PM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                  by momaka
                  03-15-2023, 10:17 PM
                • Dani_2024
                  by Dani_2024
                  10-28-2024, 05:06 PM
                • black6host
                  Replacement caps for Samson Resolv studio monitor 65A Amp board.
                  by black6host
                  Good day!
                  I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                  I'm going to replace the caps and I'll be the first...
                  02-06-2024, 08:22 PM
