What tests should be run to confirm system integrity on a board that has been recapped.
The recapped board (repaired at badcaps.net) has been installed, it boots to windows and seems fine at this stage.
What I was going to do was run the following applications.
1. HDD full diagnostics
2. Run Memtest86 for 24hrs
3. Run Prime95 (multiple tests) for 24hrs each
4. Run 3Dmark for about 20-24hrs
Pretty much the same tests that I would use to check an overclock.
Are these tests sufficient to confirm that all the new caps / mobo are working fine, or is there something else that I should be running.
Many thanks for any info provided.
Cheers
Cheers
what did we say about hoarding too much stuff and depriving others of them?! *cough* socialism *cough* lol!
