ENW caps?
    • 30952
    ENW caps?
    anybody seen these or got a datasheet?
    Ryobi chargers are full of them!
    master hoarder
    • May 2008
    • 12170
    • Bulgaria
    Re: ENW caps?
    Are we talking about radial electrolytic caps here? If so, I would just ASSume cheap CN/TW garbage. Also, where are they used in the charger and is the charger linear or SMPS? If you know that, then you don't really need a datasheet for them to find replacements.
      • 30952
      Re: ENW caps?
      solved it, binned them and used FR
      they are used everywhere except the mains smoothing (capxon!)
      • Pentium4
        CapXon Be Gone
        • Sep 2011
        • 3741
        Re: ENW caps?
        Pics?
          • 30952
          Re: ENW caps?
          of? the charger or the caps?
            Re: ENW caps?
            FYI:
            http://www.enw.hk/en/
            • Pentium4
              CapXon Be Gone
              • Sep 2011
              • 3741
              Re: ENW caps?
              Either
                • 30952
                Re: ENW caps?
                later then - i'll dig a couple out and foto the internals.
                it's the limegray Ryobi-one chargers.
                i found a common fault on them because of a design flaw.
                they all blow up within 2 years!
                i also have a fix for it - as you would xepect..
                  • 30952
                  Re: ENW caps?
                  Originally posted by budm
                  i knew about that - try to download the pdf!
                    • 30952
                    Re: ENW caps?
                    pics.
                      master hoarder
                      • May 2008
                      • 12170
                      • Bulgaria
                      Re: ENW caps?
                      typical of a cheap cap website.
                      We still gotta give credit to budm for finding the website, though. That's one thing I could never do well (perhaps because I also rarely bother to thoroughly look up manufacturers of cheap caps for the same reason above).
                        by momaka
                        03-12-2025, 03:42 PM
                      • eryjus
                        by eryjus
                        05-10-2023, 11:21 AM
                      • Paxman_Swede
                        by Paxman_Swede
                        Hello!
                        01-14-2025, 09:51 AM
                      • captain150
                        by captain150
                        03-16-2025, 07:34 PM
                      • Foetuss
                        Gigabyte GA-6OXT :: caps question
                        by Foetuss
                        Good evening
                        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                        But I was also suprised about the bigger boys, which are 330µF 25V.
                        Could it be they used 25V caps because they were cheaper / available at that time?...
                        02-11-2025, 12:22 PM
