Help to identify SMD capacitor markings.
  • Doramius
    • Nov 2007
    • 25
    I need to replace a surface mount capacitor but not sure what the markings mean. Surface mount became popular after I finished electronics at a vocational school years ago. (I know, I've practically given away my age) Looks like it was just a bad solder connection, but the capacitor is ruined.
    These are the markings:
    Any help would be appreciated.
  • gonzo0815
    • Feb 2006
    • 1600
    Re: Help to identify SMD capacitor markings.
    I think it is an tantalum capacitor, so i would guess it is 10uF, 35V (that is the usual notation).
    But if you want to be sure, you have to figure out the manufacturer and lock at the data sheet.
    • Doramius
      • Nov 2007
      • 25
      There's no other markings to determine manufacturer. It was in an external enclosure made by Formac. the enclosure doesn't even say the model type.
      It says made in Germany.
      • gonzo0815
        • Feb 2006
        • 1600
        Well, probably an older part from AVX. At least the black / white labelling is used by them still today at some of their high reliability tantalum's.
        But usually they print the series on it too. May be the M8 is the series, but then it is probably an older one.
        • Doramius
          • Nov 2007
          • 25
          I'll see if I can search them out, unless you have a link? The device the cap went to was manufactured in 2001, so it's quite possible it is an older series. I just have no clue how to look up the specs. I don't know how many places would go back to 2001 in specs though.
          • gonzo0815
            • Feb 2006
            • 1600
            I would try www.avx.com, but i think you will not get the old data sheet there. Their site is a little unsorted.
            • Doramius
              • Nov 2007
              • 25
              I never did get an answer from the site. I sent a few messages with no reply. Still no luck in figuring it out. I may have to unsolder an existing one and hopefully my tester will be able to properly read it.
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                its just a standard sm tantalum
                hit the digikey site and you will find them.
                if it were mine and i didnt have that cap on the shelf i would try a low esr lytic.
                • MORETTIGIAN
                  by MORETTIGIAN
                  Title:
                  Description:
                  Procedure performed:
                  - Removed backplate
                  - Reapplied thermal compound
                  - Reassembled card
                  09-18-2025, 12:14 PM
                • BlackBurn
                  Help to identify a laptop mainboard SMD capacitor LA-9982P
                  by BlackBurn
                  I have an Dell Inspiron 15 3537 laptop mainboard (LA-9982P Rev. 3.0 (A02)) with a blown SMD capacitor as shown in the attached images. However, there is no printed specifications near the capacitor or a codename for the capacitor to identify the specification of the capacitor to replace it. I wonder how to identify the capacitor since the mainboard schematics are also useless as the capacitors are not named on the board. Any help would be highly appreciated.
                  Thank You. Stay Safe.
                  Chamara...
                  11-27-2020, 08:30 AM
                • Stunt
                  Help me identify this chip the markings is AKLG 302
                  by Stunt
                  Hi i need somebody to help me identify this chip the markings is AKLG 302. It's on Hp Pavilion 14-am 245 G5 6050A2823301-MB-A02 motherboard
                  06-19-2023, 12:30 PM
                  Surface Mount Fuses Fundamentals Datasheet
                  TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                  TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                  10-07-2024, 06:07 AM
                • chth96
                  by chth96
                  12-22-2023, 04:34 AM
