Need help identifying value of this bad SMD cap.
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    We have a broken Microsoft Mobile Wireless Mouse 6000. We have found at least one issue with it, a broken SMD cap. There might be more. I can't seem to find a schematic for this mouse and was hoping someone could help me identify a correct replacement. The board lists it as C38. Here's a picture. Any idea how I can identify what the original value was? Thanks!
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
  • Spork Schivago
    • Mar 2012
    • 4734
    Re: Need help identifying value of this bad SMD cap.
    Forgot to say, in the picture, the cap I'm talking about is the tanish / yellow / brownish one that is physically broken in two. Thanks.
    • Spork Schivago
      • Mar 2012
      • 4734
      I wonder if the transistor looking component, Q5, is actually a zener diode. It says VB and has a sideways P on it. Could it be a BZB84-B3V0 SMD zener diode? We found another one on the board that appears to have an SMD resistor and an SMD cap on it. Perhaps I could try pulling the cap on that one and checking the value. They're probably the same value, right?
      • Spork Schivago
        • Mar 2012
        • 4734
        The other transistor looking SMD component with the same markings, VB sideways P has a resistor that in-circuit measures around 800 ohm. I can't measure the cap because I don't have needle probes for my ESR meter and my DMM says OL when I try measuring it in circuit. The Q5 transistor looking SMD components resistor measures around 400 ohm in circuit. Could these readings be different because I'm measuring in-circuit? If both of the transistor looking components really do use the same resistors and caps, maybe I could pull the good SMD cap and try measuring with my ESR meter out of circuit using those dang alligator clips to find the correct value.
          It looks to be just a small bypass cap between Base and GND, so it can be from .01~.047uF I would guess.
          • Spork Schivago
            • Mar 2012
            • 4734
            Thank you Budm! So what does a bypass cap do? What's the point of putting one between Base and GND? Thanks!
              OK, I look at the trace at the right side of the cap, it is not connected to the Ground plane but to that round pad which go to the other side of the board, so it can be a coupling cap, you need to see where it goes to.
              BTW, is it also connected in parallel with R29?
              • Spork Schivago
                • Mar 2012
                • 4734
                I do believe it's connected to R29 in parallel. It was hard to see with the broken piece there, but I carefully used an exacto knife to move part of the broken piece out of a way and I see two traces going from the resistor and the cap. One trace at each line, like this:
                Code:
                |C |  |R |
                It's hard to see where it goes once it goes through the via to the other side. There's some sort of metal oval can on the other side, I think it's a crystal for timing. The trace seems to go under that piece. I can remove it if you need me to and take a closer look there on the back side. The crystal type thing says on it: CMT-LLAZ(or 7)I(or1)C
                On the board next to it, it says Y2. There's another one on the board as well. I believe the Y reference designator generally refers to a crystal or oscillator.
                • Spork Schivago
                  • Mar 2012
                  • 4734
                  If it is a coupling capacitor, that means it blocks the DC but allows the AC to go through. Would that be used for the wireless transmissions? I know coupling caps are used with audio circuits a lot to block the DC so you don't get the hiss and crackling and stuff, right?
                    Since it is in parallel with the resistor then it is not a coupling cap to block DC due to the fact that the resistor will let the current flow through.
                    Did you check the value of the resistor?
                    How about the pictures of the whole board?
                    That device can be Transistor or MOSFET, did you do the Diode test to find out if it is PNP, NPN, etc?
                    • keeney123
                      Lauren
                      • Sep 2014
                      • 2536
                      It looks like some type of ceramic capacitor.
                        It is MLCC.
                        • Spork Schivago
                          • Mar 2012
                          • 4734
                          I did check the value of the resistor, but on-board. I can remove it and test it out of circuit. On-board (which probably didn't get me an accurate reading) showed it to be around 400 ohm. I will post pictures of the whole board, front and back, in a little bit.
                          How do I do the Diode test to find out of it's PNP, NPN, etc? I've measured the continuity between the various pins. If we call the very top pin (the one all by itself), pin 1, and the bottom left pin, pin 2 and the bottom right pin, pin 3, these are the readings I get when I have (B stands for black probe, R for red probe. Black probe is hooked to COM, red probe is hooked to ohm):
                          Code:
                          [FONT="Times New Roman"]
                          B R
                          1 - 2: 20 Megaohms, slowly counting down
                          1 - 3: 60 KOhms, slowly counting down
                          2 - 3: 0.403 Megaohms
                          R B
                          1 - 2: 0.43 Megaohms, slowly counting up
                          1 - 3: 143.2 KOhms, but it was higher, jumping around a bit, and finally stayed there
                          2 - 3: 28.75 Megaohms, slowly counting down.
                          [/FONT]
                          Pictures are uploaded now. Once my wife gets home (around 3:00 - 3:00pm today), I can have her hold a light and try to get better pictures with better lighting. Let me know if you need those. I can also zoom in on different parts and take better pictures there.
                          • Spork Schivago
                            • Mar 2012
                            • 4734
                            Is it possible that there's more than just two layers here? I use my needle probes and I put them on that hole next to the bad cap. Then, on the other side, I've tried every hole around there and I can't get any readings at all. But if I have one of my probes on that hole and test the continuity to a capacitor or resistor, I get continuity. Really high resistance though, like .405 Megaohms. So I'm certain my needle probes are small enough to get into the hole...
                            • Spork Schivago
                              • Mar 2012
                              • 4734
                              Pulled the little tiny resistor and measured it at 393 Ohm. I'm guessing it's supposed to be a 400 ohm resistor. Gonna try getting it back on. It's really, really, really tiny. Never played with suuuuchhhh a small resistor. There'd be no way to hand solder it because of how small it is. Even the tip on my micro soldering iron is a lot bigger than this whole resistor. The pads I can barely see. Gotta use a magnifying glass.
                                Test in Diode mode both directions of the probes.
                                • Spork Schivago
                                  • Mar 2012
                                  • 4734
                                  My DMM doesn't have a Diode mode Budm. It's a very old Craftsman True RMS DMM. It's Craftsman True RMS AutoRanging Digital Multimeter, 82357
                                  Here's a link to the one I have:
                                  http://www.machine--tools.com/By-Typ...ter-82357.ASPX
                                  • Spork Schivago
                                    • Mar 2012
                                    • 4734
                                    In Ohm mode though, with black probe on D (C), I get
                                    D (C) -> G (B) = 20 Megaohms, slowly counting down
                                    D (C) -> S (E) = 60 KOhms, slowly counting down
                                    With red probe on D (C), I get
                                    D (C) - G (B): 0.43 Megaohms, slowly counting up
                                    D (C) - S (E): 143.2 KOhms, but it was higher, jumping around a bit, and finally stayed at 143.2 KOhms.
                                    With black probe on G (B) and red probe on S (E), I get 0.403 Megaohms.
                                    With red probe on G (B) and black probe on S (E), I get 28.75 Megaohms, slowly counting down.
                                      The Ohms mode so far showing it is not shorted out, you need diode mode to test the PN junctions.
                                        • 31029
                                        too bad i cant make out the writing in those foto's
                                        i refuse to believe that a meter with true-rms and a serial interface is lacking a diode test.
                                        • Sam Scarbo
                                          Sparkle 1200W PSU MAGNA Model: SPM1200AXJ8 - Broken. Need help identifying components. Any schematics available?
                                          by Sam Scarbo
                                          My Sparkle (SPI) PC power supply has broken. Originally, there was totally no power output. The 5V-standby was not there. I have replaced a few bulged capacitors but not helping.
                                          I was trying to do more troubleshooting but burned more components. Some got burned so badly that the markings were gone. And also, the markings of a few transistors were gone because the component surface was worn out somehow.
                                          If you happened to have disassembled the same PSU model, please help to provide the markings of some of these components.
                                          See the attached two pictures of the small...
                                          09-18-2024, 08:29 AM
                                        • LaptopSugar
                                          Please identify the broken blown component dell precision 3520 la-e153p
                                          by LaptopSugar
                                          Please identify the broken blown component. The pictures and schrmatic are attached. The 5 pin nextdoor refers to the dc cable. I think iy is the 1000p 50 0603 v7 cap but im not sure. Am i correct. the images are attached pleas help
                                          The images followthe first is thebroken conponent, rhe second another board, the third the schematic, idought itsthe yello highlighted one on left...
                                          06-25-2024, 04:23 AM
                                        • chth96
                                          Is it possible bridging tiny broken trace
                                          by chth96
                                          When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
                                          cutting tiny trace.
                                          This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
                                          Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
                                          But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
                                          12-03-2022, 11:32 PM
                                        • FreakyMex
                                          Trouble to identify part (Lunii screen) for replacement
                                          by FreakyMex
                                          Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
                                          I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
                                          02-17-2025, 01:16 AM
                                        • matheus30
                                          Help identifying two components of a laptop gaming screen.
                                          by matheus30
                                          Good evening, can you help me with a complicated repair?
                                          I'm repairing an LED screen gaming notebook. The screen has a short circuit, and when the notebook is plugged in, it won't turn on. I found the short by removing the coil in the red circle, and by injecting voltage, I see that the Richtek power supply in the blue circle is heating up. Therefore, I have located the fault.
                                          But I have two problems:
                                          1. The most serious is that I accidentally lost the coil, and I don't have a photo. I can also tell you that there was nothing written on it. Can anyone who has seen that...
                                          04-14-2025, 04:11 PM
