Identify capacitor C47B on Polaroid 200-P00-HIVI150H power supply/inverter board
  • SdlewisSr
    • Oct 2015
    • 146
    Hi everyone
    I need to replace capacitor C47B (C47B Capacitor.JPG) on the power supply/inverter board 35-860-AZ0-IPOS150H (200-P00-HIVI150H) (200-P00-HIVI150H.JPG) of the Polaroid TLX-03210B.
    The capacitor is burnt and therefore I cannot figure out what replacement I need. Does anyone have any idea what the specs on this capacitor is or where I can purchase a replacement?
    Thank you all in advance for your input/help
  • R_J
    • 9551
    Re: Identify capacitor C47B on Polaroid 200-P00-HIVI150H power supply/inverter board
    I would think its the same as c46a, or maybe even c44, looks like there are 2 identical circuits, the one with the blown cap. and the other off of T4
    maybe a .01 at 2kv or something like that, get the numbers off the other blue caps in the 2 Hv output circuits
    • SdlewisSr
      • Oct 2015
      • 146
      Thanks R_J for your suggestion. The other two near it are CH 10J 3KV. I took some alcohol to the burnt one and can make out that it is also the same.
      Now I just have to find a replacement. I should be able to find one now that I have the specs.
      Again, thanks R_J
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Here is what you need, have you checked for S/C on the driver transistors ?
        http://www.ebay.co.uk/sch/i.html?_fr...+10kv&_sacat=0
        • SdlewisSr
          • Oct 2015
          • 146
          Hi ReeceyBurger123,
          Not sure what you mean by "S/C".
          The link http://www.ebay.co.uk/sch/i.html?_fr...+10kv&_sacat=0 has the numbers reversed (3J 10KV instead of 10J 3KV), but it lead me in the right directions. Thanks
            • 31061
            s/c = short circuit
            • SdlewisSr
              • Oct 2015
              • 146
              Thanks stj for the clarification.
              ReeceyBurger123 I have not checked any further than this capacitor. When the TV comes on the screen comes on and off three times and then this capacitor starts smoking.
              OK. I know that the capacitor is 10pF 5% tolerance 3,000 volts. Does any one know what the "CH" stands for in "CH 10J 3KV"?
              • R_J
                • 9551
                Looks like its temp. compensation, I would'nt worry too much about it.
                If c47b and c44 are in parallel I would remove c47b and see if the display stays on. It should not hurt anything for a short period, 10 - 20 sec. the high voltage must be working or the bad cap would not be smoking.
                I'm sure this from digikey would work 1247PH-ND
                  • 31061
                  take the cap out and meter it for resistance.
                  • SdlewisSr
                    • Oct 2015
                    • 146
                    Great call R_J
                    Though c47b and c44 are NOT in parallel, I removed c47b and the TV works just fine without it. I noticed before that there is NO corresponding c46b and was curious why. There is a corresponding capacitor for c44, but not c47b. Either way it works fine. I will replace it anyway just to be on the safe side.
                    Thanks everyone for your help!
                    • SdlewisSr
                      • Oct 2015
                      • 146
                      For anyone interested, I found this capacitor tutorial very helpful. On page 6 it explains what the CH stands for in "CH 10J 3KV".
                        http://assets.shopjimmy.com/media/ca...h-bottom_2.jpg
                        As you can see the 47b is connected between GND and the high Voltage output of the inverter transformer. I would not keep running without the cap in place, it is there for reason.
                        • SdlewisSr
                          • Oct 2015
                          • 146
                          Thanks budm. I only let the tv run without the capacitor long enough to see that the tv works without it.
                          • chth96
                            What capacitor should I purchase for Power Supply of obsolete game consoles?
                            by chth96
                            hello.
                            I have Sega Saturn and 5 years ago, I recapped all of capacitor in the Power supply, Because At that time, It frequently freezed black screen after SEGA logo displayed.
                            It hardly ever freezed after I finished to recap all of caps in the power supply.
                            But Yesterday, It did not show any screen at all and its green power LED constantly blinked.
                            To my surprise I found that all of two NXH 10v 2200uf capacitors in the secondary area of Power supply have been bulged and It measured 57 mF and 75 mF capacitance.
                            It seems that quality...
                            10-01-2024, 08:14 AM
                            DVR camera recorder switching power supply capacitor failure really
                            by sam_sam_sam
                            These cheap non brand capacitors at it again
                            Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
                            Well at least I have the cameras back on line I to try the...
                            01-22-2022, 06:28 PM
                          • r2digital
                            klipsch kda-500 amplifier suitable power supply capacitor replacement ?
                            by r2digital
                            I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
                            04-18-2024, 03:50 PM
                            by sam_sam_sam
                            07-01-2024, 06:34 AM
