How to Recondition (Reform) Electrolytic Capacitors and Why
This is a sticky topic.
  • Eaglecrest
    • Jul 2018
    • 163
    Any bulb above 50 Watts should do really, but I generally recommend above 60W. The higher the power rating of bulb, the more current that can be drawn by the device (both at start-up and continuously). 60W will probably allow you to run the amp with a small load. 100 Watts bulb should allow you to crank it up a bit more. Not much of a difference otherwise. I've even used 40 Watt bulbs in a pinch, too - works with devices that have a lower idle power draw.
    This is a while since the post was made, but I finally got around to building the dim bulb tester. I used a 75 W bulb and used it on a number of flat panel monitors and a pc. In all cases the bulb glows and then goes out and cycles this way continuously. The devices turn on then off with the bulb. I was expecting the device to turn on and the bulb to turn on then go off if all was working well and for the device itself to keep power. What is this behavior telling me?
      • 32069
      use a larger wattage lamp, the psu isnt getting enough power to start up.
      made worse btw if the device has active PFC in it.
      • Eaglecrest
        • Jul 2018
        • 163
        I moved up to a 100W bulb and it will now power up LCD monitors, but I have a 21" multisync that still won't power up (blinks). There aren't many options for higher wattage, as I understand it I will need to use multiple bulbs and I believe i need to connect them in parallel, is this correct?
        How do I figure out what wattage I need for various different equipment?
          • 32069
          parallel lamps is correct,
          most equipment has the wattage or amps marked on the back - going double that to allow for inrush is probably fine.
          • goop
            • May 2014
            • 52
            • state
            #145
            Are there ready-made capacitor reformer / reconditioner devices?
            Sounds like a simple enough device you'd find from the usual Chinese sources, but my limited searching came up empty.
            • Masouda ipzi
              • Sep 2023
              • Iran
              • Repairing electronic stuff
              #146
              Refilling electrolyte into aluminum capacitor. I have the knowledge about how injection electrolyte (fluids) into the can.I've passed my (QC) . as you can see I refilled electrolyte into capacitor and then I installed them inside LED light bulb. Capacitor body temperature was about 70-75 centigrade.they revived.
              in the future I will upload more pictures
              after injection and reforming process, the ESR dropped about half. If a capacitor have about 10 ohm , after reforming it will drop to 5 ohm
              it's a long long story
              • Masouda ipzi
                • Sep 2023
                • Iran
                #147
                Old Panasonic (Matsushita) with High ESR and Droped capacity have been revive with injecting electrolyte fluid into it.
                Before injection and after injection
                i invented this method
                sorry for my bad English
                i am (Masouda ipzi) from Iran
                • Masouda ipzi
                  • Sep 2023
                  • Iran
                  #148
                  • Masouda ipzi
                    Masouda ipzi commented
                    Editing a comment
                    P.S then i installed the capacitor into LED light bulb. Capacitor body had 70 centigrade heat with no problems
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8887
                  I don’t recommend doing that unless you go no other option left. Also if you look at the results, you went from 10 ohm ESR down to 5 ohm, that is still bad in my book. It’s like the trick with a used sulphated car battery. Dump acid, hot wash it, dump it again, refill with new acid. Or filling in a small 12V 7Ah SLA with battey acid, to gain a few more years. Battery will perform somewhat again, but not like a new one. I’ve been doing desulfation tricks for over 15 years (just because I can).
                  Then let’s talk about the seal (to close the hole you drilled on top). Ever seen what the capacitors electrolyte does to copper and solder once it leaked out a capacitor? You sealed it off with solder? Why do capacitors leak first place?
                  Boy… I’d be in big trouble if I’d repair stuff this way.
                  While this can be done and you are not the first one to do it, this can spell real troubles. Anything from an exploding cap to spewing acid around into potential sensitive or high voltage electronics.
                  • madscientist750
                    Replacing electrolytic caps by solid caps on old motherboards
                    by madscientist750
                    I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
                    I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
                    I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
                    10-19-2025, 06:10 AM
                  • Perry Babin
                    Electrolytic cap endurance
                    by Perry Babin
                    From what I've found, the endurance of a liquid electrolytic cap is determined by the loss of electrolyte. If a cap is rated for 1000 hours. That's typically for a straight run test. How would the life vary if the cap is intermittently heated to its rated temperature (105C). Maybe for an hour at a time then cooled back to 30-40C (just a random number). Would the life still be 1000 hours?
                    Does it make a difference in the life expectancy if the cap is heating from ripple current (internal heating) instead of from the external ambient temperature?
                    Why do polymer capacitors...
                    10-18-2025, 05:21 PM
                  • Perry Babin
                    How do organic polymer caps compare to liquid electrolytic for reliability
                    by Perry Babin
                    I have a situation where a power supply is commonly abused and the 12v supply caps take a beating. They don't commonly fail but they run hot. I was thinking about going from a liquid electrolytic (Panasonic FC and Nichicon HE) to an organic polymer. The values have been 330uF. I typically use a higher-than-needed voltage to get a lower ESR. The supply is operated from 12v.
                    If not organic polymer, what would be the caps that could take the most abuse?
                    08-18-2025, 04:04 PM
                  • ten-d
                    Nippon Chemi-con 100uf 100v BP electrolytic cap
                    by ten-d
                    Hi all!
                    I just bought a pair of ADS L810 speakers, which I've heard are some of the best speakers from that time (late 70's) into the early 80's. I was super excited to test them out and hooked them up and I was very underwhelmed by the treble. The treble was awfully muffled. I've been doing some restoration work on 70's stereos and a couple of speakers here and there so I am really just a beginner. I do know that capacitors in speaker crossovers filter out the lows to allow only the highs up to the tweeters and mids. Inductors filter out the highs to allow the lower frequencies to...
                    01-30-2024, 05:18 PM
                  • Adenitz
                    Replace electrolytic cap with bipolar one
                    by Adenitz
                    can I use this cap:
                    https://www.tme.eu/en/details/ues1h4...tors/nichicon/
                    Capacitor: electrolytic; bipolar; THT; 47uF; 50V
                    to replace this capacitor: Electrolytic Radial E 47uF/50V 6.3x11 RM2.5 105°C Jamicon
                    What exactly I can expect to install bipolar electrolytic cap instead a regular one?
                    Thanks.
                    02-02-2022, 07:44 AM
