Re: Advice on replacement caps for Netgear WNDR3700
a tip should not be damaged with normal electronic solder, only if someone is using a very agressive flux that shouldnt be used on pcb's
aluminium or stainless-steel solder comes to mind.
Half of the computer problems is caused by bad contacts
Thought I was odd fabricating tips from copper since those Hakko tips are scarce in this crappy country am at.
