Samxon capacitor quality discussion (spin-off from OCZ Bug Zapper thread)
  • Wester547
    • Nov 2011
    • 1269
    • USA.
    #61
    Re: Samxon capacitor quality discussion (spin-off from OCZ Bug Zapper thread)
    Never soldered or had bias applied, but these are a "cut lead" lot. A failed 1500uF measures with C of about 2500uF and anomalous high leakage current - the tester claims that is a cell (i.e. battery) in one direction and diode with Vf=274 mV in another (typical for thinned or non-existent oxide - it probably shares some characteristics of metal-semiconductor diodes).
    Sounds like the aluminum oxide film has been corroded by the highly water base electrolyte, potentially causing a partial short in the dielectric and high leakage current. Things might have changed if they were actually used and kept cool with the ripple current low, over the course of many years, but KZGs that old might just be doomed to failure.
    A good (non-bulged) 1500uF/6.3 measures as 1805uF/40 mohm and Vloss of 1.8%. Slightly high, but still almost within the 20% spec for capacitance after 12 years, so it's not too bad.
    NCC states in the datasheet that if capacitance is within 25% of the nominal capacity after the endurance test, it's still good. 0.040 ohms is a tad high, but if the contact resistance at the leads is an issue, it might not be cause for concern.
    Clearly, they missed something in the formula for KZG versus KZE. It should have been easy to fix, unless the two electrolyte formulations are vastly different in their electrochemical reactions, which seems unlikely.
    The KZG sheet says that it uses the same "advanced electrolyte technology" as KZE. The difference must be in the concentration of ions, or the amount of water, or how conductive the electrolyte is.
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      #62
      Originally posted by linuxguru
      I think that some NCC KZGs were outsourced - maybe to Korea Chemicon or Samyoung or similar. Whether that was the cause for the KZG failures, I don't know.
      I don't believe so, here for example are KZG caps with two different datecodes produced in the same factory (Japan - Tokyo as Wester points out)
      But only one of the datecodes from the same factory had failed:
      https://www.badcaps.net/forum/showpo...12&postcount=8
      • Wester547
        • Nov 2011
        • 1269
        • USA.
        #63
        Originally posted by Wester547
        1. gamma-Butyrolactone (GBL)
        2. Dimethylformamide (DMF)
        3. Dimethyl Acetal (DMA)
        Also, I meant Dimethylacetamide, not Dimethyl Acetal. I was basically referencing lactone and select amide solvents, IE solvents that can handle temperatures of -55C and lower.
        As for KZGs, I think they're just unpredictable. Some part of the formula or solution must be wreaking aggressive havoc upon the rest of the materials, hence the frequent generation of hydrogen gas and failure even on the shelf. But to be more on-topic to the thread, at least it can be said now that Man Yue try to manufacture decent capacitors, unlike most other Chinese brands.
        • Behemot
          • 4845
          • CZ
          #64
          Just for some upgrade after 5 more years, I had two RS 330/25 caps (or something like that) dead in an old router some time back, but that thing was running quite warm for many years 24/7 after recapping it.
          So far, did not get any single confirmed case of dead RS 3300/16 D10x30 mm I sourced years ago directly from the factory. I already sold or used up about half of it, which means I still have over 2000 pcs left, which are also just fine.
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16959
            I actually had a Dell SX270 come back on me a year or so ago that I used Samxon GC's on....recapped circa 2009. I don't know what they use that system for, but they wanted it recapped again. I polymodded it this go-round.
            <--- Badcaps.net Founder
            Badcaps.net Services:
            Motherboard Repair Services
            http://folding.stanford.edu/
            Team : 49813
            Join in!!
            Team Stats
            • Behemot
              • 4845
              • CZ
              #66
              Most of those caps died after 11 years of use no matter was it Sanyo, Rubycon, Nichicon or NCC (obviously) caps, especially in these terrible Dell systems. That's pretty much confirmation Samxons were on par with those ultra-low ESR caps.
              Polymers only have a chance of surviving longer, although I doubt they'll still use it after 2030
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16959
                Absolutely. My observation/reporting of this failure wasn't intended as a criticism. These systems roast even the best panasonic lytics. Horrible design. The GC's hung in nearly 10 years, not bad considering the circumstances.
                Geez, I hope not....but then again, I didn't expect it to still be in use now...
                Team : 49813
                Join in!!
                Team Stats
                • Behemot
                  • 4845
                  • CZ
                  #68
                  Who knows, I've already repaired strange IBM systems with Socket 478, reportedly it runs some huge printer, if you had gazilion printing material for close to nothing, you'd also keep such beast alive, so maybe it's similar case.
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16959
                    I recap a bunch of proprietary MSI socket 478 & early LGA775 boards for several clients that runs these as some kind of controller for some kind of industrial printers/plotters. If it has a purpose, its age really doesn't matter...
                    Team : 49813
                    Join in!!
                    Team Stats
                    • Behemot
                      • 4845
                      • CZ
                      #70
                      Most funny's that the huge printer machine is HP but the controlling PC's IBM, as far as I've heard, never really seen the whole thing
                      • Logistics
                        • Apr 2007
                        • 721
                        Been browsing this thread here and there. I can see the standpoint that there may be fake Samxons due to differing results experienced by different techs. I used Samxons I bought from BigPope (iirc) on motherboards and PSU's, and didn't have any trouble, later. But I believe that particular system was a slot P3 so not high stress.
                        • DXseekerMO
                          Backlight strip quality, Amazon vs Ebay vs ShopJimmy. Is there really a difference?
                          by DXseekerMO
                          Hello everyone!
                          Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
                          I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...
                          Yes
                          0%
                          1
                          All backlight strips are the same quality
                          0%
                          1
                          No
                          0%
                          0
                          12-16-2021, 03:58 PM
                          Light that has a bug zapper in bottom section of light fixture the LED light module took a crap but the zapper still works
                          So I got the bright idea to remove the LED light module from the fixture and put it on top of another enclosure and keep using the zapper
                          The removal of light module was a successful and now I just have to cut a hole in the enclosure and put a power cord that has an on and off switch on it
                          You are lucky to get about two years of service out of one before the LED module starts flicking and just stops working because it is mounted on an aluminum plate and these are hard to solder on it and it is not worth messing around with them and especially this one because it has line...
                          09-07-2024, 07:26 PM
                        • chth96
                          Can I replace KME cap with Samxon GF cap?
                          by chth96
                          Hello.
                          I have 29inch LG CRT TV,And Yesterday,Whenever I connect AC power cord to power outlet without switch on, I heard a sound like white noise, And When I switched on this CRT TV, It sometime displayed correctly But usually It won't last more than 20 minute and The screen begin to dark and It finally did not display at all for hours..
                          Today,I dismantled its plastic case and discharged the biggest capacitor(400wv 470uf) which still holds 250 voltage,and I finally detached PCB from cathode-ray tube.
                          I measured ESR value of most of caps in PCB with MESR-100 and I found that KME(25v...
                          04-17-2024, 07:11 AM
                        • ckrtech
                          Help Identify cap brand and quality, please
                          by ckrtech
                          This is a cap on a motherboard from 1994. “Ark” is the only brand I know of that has an A inside a rectangle, but I wanted to run it by you guys and get any thoughts on quality.
                          Thanks in advance....
                          06-09-2025, 12:28 PM
                          Boston Acoustics HD8 – build quality impressions & DIY woofer surround repair
                          by momaka
                          Boston Acoustics fans, this thread might not be for you.
                          A few years back (~2018 time frame), I picked up a set of free JVC speakers from someone on Craigslist that no one seemed to be interested in. The guy also had a single Boston Acoustics HD8 speaker – yes, just one cabinet. He said he had no idea where he got this one from or why it's only by itself. But like the JVC speakers, it was going to get tossed at the end of that week… so I came to collect, as usual. And that's all I know about this HD8. After all, I figured why not take it and see what's inside… show it to the...
                          01-30-2022, 11:57 PM
