esr of hid lighting caps
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    had a cap on the shops hvac blower die.
    its a 10@370.
    had degraded to 6uf.
    caused hard starting of the blower.
    esr of 70mohm.
    had a junk hps fixture with a 10@400 about 5 times the physical size.
    its esr is .23!
    i assume its junk but there is no esr ratings in the datasheets for these caps.
    it made things better till the new one gets here monday.
    i ASSume the larger can is for lower esr and more surface area to dissapate heat.
    anyone have such a cap new and an esr meter?
    • 31289
    Re: esr of hid lighting caps
    larger can usually coincides with higher ripple current.
    • delaware74b
      • Apr 2009
      • 628
      Coincidentally, I will be working on 1000-watt pole fixtures tomorrow. The caps used are 24uF 480-volt wet oval cans. If I get a chance, I will try to get esr of a few new ones as well as the duds. The caps I replace have a 3% tolerance. I don't worry about the new ones being higher as much as I worry about the ones being below 23uF. The ones that have low capacitance destroy the new lamps by not allowing them to come out of startup.
      Stupidity should be a crime, especially for drivers. I have NO patience for them.
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        huh, never even thought of the ESR of these HVAC/Lighting caps. Though in such situations i wouldn't think ESR to be too big of a deal. I mean all they really do is provide phase shift and current limiting.
        Follow the white rabbit.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16959
          i've got a new old stock holophane champ series 150w HPS light. I'll see whats in it.
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • delaware74b
            • Apr 2009
            • 628
            I brought home 2 caps today from work, a new Aerovox 24uF 480V AC cap and a 1997 bad cap which is also 24uF 480V AC. These caps are used in a 1000Watt metal halide light fixture. The cap is wired in series from the output of the ballast to the center contact of the lampholder.
            The caps are oil-filled wet caps with a bleeder resistor across the pins. Tolerance is +/- 3%, leaving a minimum of 23.28uF. Due to DMM calibration differences, we replace anything at or below 23uF. Aerovox publishes expected life at 60,000 hours. The site lighting where these are installed is dated to 1998, so the lighting has an estimated 63k hours at 10 hours per night since 1998.
            The ESR rating between the new and bad caps is the same at .07, measured with a freshly calibrated Anatek Blue ESR meter. Personally, I don't think the ESR matters as much as the capacitance in HID fixtures.
            The first 2 pics are the new capacitor and the last 2 are the bad cap.
              by momaka
              03-12-2025, 03:42 PM
            • eryjus
              by eryjus
              05-10-2023, 11:21 AM
            • Paxman_Swede
              by Paxman_Swede
              Hello!
              01-14-2025, 09:51 AM
            • captain150
              by captain150
              03-16-2025, 07:34 PM
            • Foetuss
              Gigabyte GA-6OXT :: caps question
              by Foetuss
              Good evening
              I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
              Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
              But I was also suprised about the bigger boys, which are 330µF 25V.
              Could it be they used 25V caps because they were cheaper / available at that time?...
              02-11-2025, 12:22 PM
