Capacitors in series max ripple
  • TELVM
    • Oct 2012
    • 547
    • Spain
    Let's say I put two Nichicon HN, 1500uF, ESR=0.009, Max Ripple=2900, in parallel on the +12V rail of a PSU.
    Combination's capacitance will be 1500 +1500 = 3000uF
    Combination's ESR will be 0.009 / 2 = 0.0045
    What will be the combination's max ripple? Equal, higher or lower than the 2900 of a single cap?
    • 31026
    Re: Capacitors in series max ripple
    ripple will double.
    • TELVM
      • Oct 2012
      • 547
      • Spain
      (Screwed up the title, I meant two caps in PARALLEL).
      So the combined max ripple of two caps in parallel of 2900 max ripple each will be 5800?
      • SteveNielsen
        Retired Tech
        • 2327
        The combined (total) current through both caps in parallel will be double the current through only one of them because the effective resistance of the circuit has been cut in half while the voltage remains the same. I=E/R. If R is cut in half then R will go into E twice as many times, meaning that I doubles.
        • TELVM
          • Oct 2012
          • 547
          • Spain
          Thanks!
          • dragon3x
            After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
            by dragon3x
            Hi, I have some 32 bits computer motherboards that need repair, as they fail to
            power on.
            Here are some examples :
            (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
            switching supply area).
            (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
            than 6.3 V.)
            1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
            I replaced capacitors with aluminum-polymer.
            3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
            03-21-2025, 02:46 PM
            by sam_sam_sam
            After all of...
            07-13-2024, 08:14 PM
          • chth96
            Is it no harm to replace with capacitor without ripple current rating?
            by chth96
            When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
            Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
            But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
            Rubycon YK DataSheet (b...
            04-19-2024, 05:19 AM
          • Ady2017
            Are there any datasheets available for Elna RJG capacitors?
            by Ady2017
            I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
            05-25-2025, 02:19 PM
          • ctroxtell
            Samsung UN70tu7000wxza no standby light, do I have bad capacitors?
            by ctroxtell
            I picked up a 70" Samsung UN70TU7000WXZA. The original owner said they were watching it when the power surged and knocked it out. I pulled the back off the TV and disconnected the main board from the power board, and the LED backlight came on, which I was told meant the power board was good. When everything is plugged in the standby light will not come on, looking at the main board BN94-17775A with a thermal imaging gun I can see one of the chips labeled 3202 is 251 degrees F just sitting idle. I found a replacement board, BN94-16115X; this board has the same symptoms, except it is a different...
            01-03-2025, 08:57 PM
