Capacitors in series max ripple
  • TELVM
    • Oct 2012
    • 547
    • Spain
    Let's say I put two Nichicon HN, 1500uF, ESR=0.009, Max Ripple=2900, in parallel on the +12V rail of a PSU.
    Combination's capacitance will be 1500 +1500 = 3000uF
    Combination's ESR will be 0.009 / 2 = 0.0045
    What will be the combination's max ripple? Equal, higher or lower than the 2900 of a single cap?
    • 31214
    Re: Capacitors in series max ripple
    ripple will double.
    • TELVM
      • Oct 2012
      • 547
      • Spain
      (Screwed up the title, I meant two caps in PARALLEL).
      So the combined max ripple of two caps in parallel of 2900 max ripple each will be 5800?
      • SteveNielsen
        Retired Tech
        • Jun 2012
        • 2327
        The combined (total) current through both caps in parallel will be double the current through only one of them because the effective resistance of the circuit has been cut in half while the voltage remains the same. I=E/R. If R is cut in half then R will go into E twice as many times, meaning that I doubles.
        • TELVM
          • Oct 2012
          • 547
          • Spain
          Thanks!
          • dragon3x
            by dragon3x
            power on.
            Here are some examples :
            switching supply area).
            than 6.3 V.)
            03-21-2025, 02:46 PM
            After all of...
            07-13-2024, 08:14 PM
          • Cama
            Solar Inverter - SMH-II - 2 missing capacitors
            by Cama
            I need help to find the value of 2 missing capacitors ( C102 and C117) on my Easun SMH-II mainboard (solar hybrid inverter). I circled it in red on the close-up picture. The 2 old capacitors are completely missing, so I have no reference. Does anyone have this board and can tell me the value or make an educated guess based on the location ?
            My model is : EASUN SMH-II 7 KW
            Mother Board : P/N 18947-002401250250
            Maybe the EASUN SMH-II 4.2 KW have the same capacitors
            Thank you...
            09-12-2025, 02:50 AM
          • chth96
            Is it no harm to replace with capacitor without ripple current rating?
            by chth96
            When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
            Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
            But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
            Rubycon YK DataSheet (b...
            04-19-2024, 05:19 AM
          • Ady2017
            Are there any datasheets available for Elna RJG capacitors?
            by Ady2017
            I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
            05-25-2025, 02:19 PM
