I have to recap a sis730 462 motherboard it has 10 2200uf x 6.3 volt from origin. The problem is that i have 5 new 2200 x 6.3volt caps and 5 new 2200 x 10volt.Can i recap using these despite their difference in voltage value.It is safe?Thanks in advance
Mix Voltage capacitor value
Tags: None
Re: Mix Voltage capacitor value
Voltages on a motherboard are 12v 5v and 3.3v.
6.3v and 10v caps are interchangeable so far as the voltage.
BUT. Volts and uF is only part of the story.
It is WAY WAY important to check the ripple and ESR ratings of replacement caps to those of the original caps.
What are the make/series of the old caps (and new).
.Mann-Made Global Warming.
- Dr Seuss
The 6.3v -10v interchangeability only applies to motherboards.
An add-in card or a PSU may have (say) 9v in there for some odd reason.
In that case check the voltage the cap is on with a meter. (Both load and no-load.)Mann-Made Global Warming.
- Dr Seuss
Old/original caps are LUXON.The new ones are JACKON (i think they are not the best)but they are the only option i have.Originally posted by PCBONEZVoltages on a motherboard are 12v 5v and 3.3v.
.Comment
Well,
If you have no choice but to use those then I guess specs aren't worth checking.Mann-Made Global Warming.
- Dr Seuss
The problem is that if 6.3V and 10V caps are connected in parallel in the same circuit there will be unequal ripple current sharing. Typically 10V caps have lower ESR. So if the caps happen to be connected in two groups keep the 10V ones together, likewise the 6.3V. ie match parrallel caps.Gigabyte EP45-DS3L Ultra Reliable (Power saver)
160Gb WD SATAII Server grade
Nvidia 8500GT 256Mb
Samsung 18x DVD writer
33 way card reader
Windows XP Pro SP3
17" Benq FP737s LCD monitor
HP Officejet Pro K5300 with refillable tanksComment
by MORETTIGIANTitle:
Description:
Procedure performed:
- Removed backplate
- Reapplied thermal compound
- Reassembled card
- GPU powers on and operates normally under...11 Photos -
by chth96I have an 21 inch CRT TV which is not able to power on.
I disassembled 21 inch CRT TV and measured voltage of main filter capacitor(Samhwa HC 400WV 220uF) in the circuit.
It shows 270V on my DMM.
So I discharged this main filter capactior completely and detached circuit board from cathode-ray tube.
Then I desoldered this main filter capacitor from circuit board.
But I noticed that this desoldered large capacitor(Samhwa HC 400WV 220uF) is slowly charged by itself until it reached 0.6V
I measured its ESR value with MESR-100 and it shows 0.1 ohm,judging...-
by Per Hansson(TL;DR skip the first paragraph)
I encountered my first dead motor run capacitor at a customer this week.
For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
(Unless a servo motor makes more sense that is).
But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
The pump would run but sometimes trip the 10A breaker.
I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
Then it could... -
by PrologHi people, I hope this is the correct spot to post this, I'm new to the forum.
I have found the board schematic (attached), but there does not seem to be a boardview available. I have never... -
by Sparklingxwhat is the easiest way to measure the capacitance of SMD ceramic capacitors and its rated voltage?...
09-12-2024, 01:04 AM -
- Loading...
