Recapping vintage communications equipment
  • metaltatorchip
    • Jun 2015
    Google has sent me here several times over that past few years for various reasons. So today I decided to register.
    I used to repair consumer electronics back into the 90's . Specializing in TVRO Satellite receivers. They had a lot of heat build up and I replaced a lot of caps. I usually just did the whole board at 1 time.
    Well now, I want to fix some old vintage ham radio equipment anywhere form 30-50 years old.
    Since it is hobby equipment it tends to live on for multiple decades. Because of that, I would like to replace the caps as few times as possible.
    I'm looking at Rubycon Nicholson Sanyo and Panasonic .
    I remember a few threads saying the FM Panasonics were a better value in that company's line.
    Things have changed a lot since the 80's and 90's so I thought I would come here for some good advice.
    I think 105C and long life are most important. Is there anything else I should be considering in my selection ?
    Tnx martin
    • 31214
    Re: Recapping vintage communications equipment
    probably best to look for something with a long life but not too low esr.
    something like rubycon YXF series.
    but it really depends what your replacing.
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      If the receivers are tube or early SS i will point you here: http://antiqueradios.com/forums
      - KE0ETP
      Follow the white rabbit.
      • mockingbird
        • Dec 2008
        • 5484
        I can give you a few pieces of advice:
        1) Use Mouser, Digikey, Newark/Farnell, Arrow, etc... Avoid "kits" for your specific model from websites that specialize in this sort of thing. You'll get a much better quality re-cap yourself, if you take a little time to read about capacitors and understand the varying quality of different series.
        2) Don't use general purpose caps, even from trusted manufacturers, and even if they're 105c rated. You can always do better, often at a lesser cost, or for just a few cents more.
        Avoid:
        Chemi-Con KMG, SMG
        Rubycon YK, PX
        Nichcion VR, VZ
        3) Don't re-cap axial electrolytic capacitors with replacement axial capacitors. There are a few outfits, specifically antique radio parts dealers, who still source newly manufactured axial capacitors from China. The problem here is two-fold: Even if you manage to obtain axial electrolytic capacitors from a reputable manufacturer (I think Nichicon might still make them), they are always general-purpose class caps AFAIK. And the ones that come from China have all the inherent problems of Chinese radial capacitors.
        4) Don't buy new old stock capacitors, even when they are an exact match. A good example of these would be the turquoise Rubycon capacitors from the 80s. I'm not saying they weren't good capacitors in their time (to the contrary, some of them still function perfectly till today), but chances are, if they've been laying around for that long, something inside just isn't as fresh as it was when it was manufactured 30 years ago.
        Regarding replacing axial electrolytics with radial electrolytics, it's pretty simple. All you do is wrap one lead in the other direction and then heatshrink it, so it functions very much like an axial version of itself.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          and if you are after originality modern parts are smaller and often fit inside the shell of the old part.caps are easy.
          i have also drilled old dogbone resistors and hid modern replacements inside.
          • metaltatorchip
            • Jun 2015
            Tnx for all the good info. Well worth the time it took to post. I learned something from every post. Tnx a million!
            • BOSCHNJAK
              by BOSCHNJAK
              ABOUT ME INTRODUCTION FILE
              2
              024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
              2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
              2022 BEV, PROJECT ?
              2021 BEV, PROJECT ?
              2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
              2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
              12-28-2023, 02:09 PM
            • Crystaleyes
              Omega MML200 Coutant Lambda PSU repair
              by Crystaleyes
              Hi all.
              Recently I picked up a vintage HP 37717B communications analyzer which uses one of these MML200 Coutant power supplies. Needless to say the PSU is not working, and surprisingly there is apparently nothing available on the web regarding repairing one of these. No stories, no schematics, zilch!
              There are however many companies offering repair 'services', however I don't have the luxury of sending it off, so am intending to do the repair myself.
              I admit right now that I am no expert on smps repair, although I do have a grasp on the principle of the general...
              05-29-2024, 08:23 PM
            • SolomonMan
              Vintage BK Precision 1403 Oscilloscope....
              by SolomonMan
              All,
              Some of you have helped me in the past and I am very appreciative of all the help! (I have fixed TVs/Stereos/ and other small appliances with your efforts...Thanks so much!!!
              Today I went to a local HAM Radio Festival. It was one of the smaller ones in our area. My stepfather is the HAM operator. I tinker in electronics but am a Software Programmer (27 years now).
              I was looking for a few odds and ends for some electronics work I have to do for the household/farm. Typically these type of shows have the grab bags or a electronics vendor...
              12-03-2023, 10:39 PM
            • proxneo
              Recapping Sony ICF-SW55 - verifying cap values
              by proxneo
              Dear reader
              I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
              At the moment, I have selected replacements based on the following list of values:
              3 x 470uF 10VDC
              3 x 4.7uF 35VDC
              4 x 47uF 50VDC
              8 x 22uF 6.3 VDC
              1 x 220uF 6.3VDC
              5 x 100uF 6.3VDC
              Which...
              06-21-2023, 12:38 AM
            • DrDos
              Kenwood KR-6030 vintage stereo ,Old Man Trying to Save a Buck
              by DrDos
              Hello all. I'll try to keep this short. I have no knowledge of electronics. I can use a multimeter and am familiar with caps to some extent. I bought a Kenwood KR-6030 vintage stereo. It need work and so I thought I would recap the thing since I get power to the on switch but nothing else is working. No lights, no sound and so forth. I went to Mouser to order caps and I find I am way over my head. I not only do not know the type of capacitors I need but Mouser and digikey do not accept Kenwood part numbers. I have the info such as 220uF 63v and such but no place to put it. I could buy a recap...
              08-08-2025, 03:16 AM
