Choosing better replacement caps for display
  • WatercoolerWarrior
    • Jan 2015
    • 6
    I have a fade-to-black monitor with clearly failed radial-lead electrolytic capacitors (bulged tops/bottoms, leaking electrolyte on the caps themselves) that I'm replacing. The capacitors in question are all 470/1000uf caps rated at 10/25V, 105C; packaging is about 10mm diameter, 16mm height, and I think 5mm lead separation. They're all manufactured by Elite (I know... I'm replacing the ones that look fine, too). I have a solid if rusty soldering background, and the basic tools for board rework, but I'm fuzzy on electrolytic capacitor details.
    (1) Is there an issue with me going to higher voltage ratings on most/all of the caps - for example, getting replacement caps all rated at 50V?
    (2) Are there other specs I need to worry about? .
    (3) From the Good Caps thread, I'm under the impression that Nichicon/Nippon/Chemicon/Rubycon/Panasonic are probably the most generally reliable brands for electrolytic capacitors. True?
    (4) Just for kicks, is there any benefit to switching to another type of capacitor?
  • selldoor
    Slow Learner
    • 7870
    Re: Choosing better replacement caps for display
    Is there an existing post for the monitor make/model. I would just use panasonic FR FM or FC in that order ( Not all sizes available in all series.) from a good source - digikey? not ebay unless you are absolutely sure about the seller.
    Depending on which monitor there may be known problem caps on the main or inverter.
    Re 4 you might have difficult fixing other caps - single sided/ multilevel board?
      • Jan 2015
      • 6
      Thanks, selldoor - I didn't even think about the fact that this may be a model with known issues.
      This is a Hanns-G HW191D monitor, manufactured in November 2007. I've attached front and back photos of the power board. Although it's a bit difficult to see (and I've done basic cleanup) all of the radial caps on the right half of the board have some leakage and swelling at top.
      • selldoor
        Slow Learner
        • 7870
        cant see any other issues - wow you have a lot of bad caps hope they have not killed anything. before you recap may be worth testing the inverter transformer secondary windings. It is the gray oblong centre top with label no starts DG1000. No Power to the board- Look on the back of the board and find the 4 corner solder joints. Set your meter on ohms 2000 and test top to bottom at each end. Also there are 3 red barrel fuses - meter on ohms 200 - result should be the same as holding your probes together. Having said that if your monitor switches on they are probably ok
        There is no need to increase the voltage ratings if you use panasonic caps.
          • Jan 2015
          • 6
          +Transformer secondaries check - about 4 ohms relative to shorted VOM.
          + Red barrel fuses, 0 ohms
          + Corner solder joints is one I have trouble with, since I don't know what I'm looking for; these are the same as the 4 screw mounting points? Looking at the board from the back, AC socket at bottom: the 2 left-hand joints and the bottom right all have zero resistance relative to each other. Top right is isolated from the other 3.
          And it looks like the replacement caps are surprisingly cheap.
          • selldoor
            Slow Learner
            • 7870
            Meter on ohms 2000 test S1 to S2 and S3 to S4
            Joints may be lacquered or have dry flux make sure you get a good contact
              • Jan 2015
              • 6
              I'm glad you mentioned the potential for them being lacquered - they were. I finally managed to make good contact on S1-S2 and S3-S4; each came out to 576 ohms.
              • selldoor
                Slow Learner
                • 7870
                That looks good then - sometimes shell out for caps then find a bad transformer
                that may be expensive or even unavailable.
                I am away for a couple of weeks hope you fix it ok
                  • Jan 2015
                  • 6
                  Thanks for your help; I've got the caps ordered and will know in a few days if this works. I went with Panasonic FR, identical ratings to the originals, but 8-9k hours rated.
                  Enjoy your time away, and once again, thanks for the help. You've saved me hours of research time.
                  • madscientist750
                    Replacing electrolytic caps by solid caps on old motherboards
                    by madscientist750
                    I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
                    I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
                    I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
                    10-19-2025, 06:10 AM
                  • black6host
                    Replacement caps for Samson Resolv studio monitor 65A Amp board.
                    by black6host
                    Good day!
                    I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                    I'm going to replace the caps and I'll be the first...
                    02-06-2024, 08:22 PM
                  • crosswinds
                    Assistance with identifying replacement caps on ASUS P5VDZ-MX
                    by crosswinds
                    So, pulled a motherboard out from storage, was working when put away, wont post when I took it out of storage today.
                    Since it was working, and it looks to be essentially time that killed it I figured its a good idea to replace the caps before digging further.
                    Looks to be only good quality caps on this board, so might not be the issue. But it is closing in on 20 years now so, wont hurt i guess
                    Its a ASUS P5VDZ-MX board.
                    I would really appreciate some assistance on what the best replacement caps would be for these:
                    Panasonic(M)...
                    04-17-2024, 04:25 PM
                  • HectoPascal
                    Replacement caps ok? (smoothing caps, PSU heating controller)
                    by HectoPascal
                    Hallo,
                    i want to replace two smoothing caps from a heating controller PSU. They are probably 30 years old and it might be time to replace them.
                    SXE 470uF 63V 105°C (tested: 472uF 0.35Ohm) --> Nichicon VY 105°C - 463uF 0.15Ohm
                    SXE 470uF 25V 105°C (tested: 422uF 0.63Ohm) --> Samwha K5A 85°C - 446uF 0.10Ohm (or Panasonic RAD FC 470/25 8mm)
                    I couldn't find anything about 'SXE'. That's the only declaration on the caps. Edit: The top/bottom ident says Nippon CC.
                    Nichicon should be 'VY' series (linked).
                    I couldn't find anything about Samwha...
                    09-06-2023, 08:30 PM
                  • Perry Babin
                    How do organic polymer caps compare to liquid electrolytic for reliability
                    by Perry Babin
                    I have a situation where a power supply is commonly abused and the 12v supply caps take a beating. They don't commonly fail but they run hot. I was thinking about going from a liquid electrolytic (Panasonic FC and Nichicon HE) to an organic polymer. The values have been 330uF. I typically use a higher-than-needed voltage to get a lower ESR. The supply is operated from 12v.
                    If not organic polymer, what would be the caps that could take the most abuse?
                    08-18-2025, 04:04 PM
