I was originally Solder Boy here on the forums now I'm Scavenger ( don't ask lol)
Anyhooo after a long abscence from recapping motherboards, I decided to tackle a couple of boards yesterday... the first one had no video and I recapped it and it worked no problems... I thought great!,let's try another.
The 2nd one is a ASRock GE Pro-M2, it's problem was that it would turn on but no video. It had 5 blown capacitors that were the small ones 6.3 Volt 1000uf caps. I replaced them with OST ones. Anyway turned it on, and voila I had video
Then to my dismay the board shut off.
Looking on the back of the board, I didn't see any obvious signs of the solder on the traces, which would be not hard to do because of the way this board was designed.
I don't have an ESR meter to check the caps I used... I'm guessing the caps I used must be bad... would that be a correct assumption?
Then to my dismay the board shut off.Looking on the back of the board, I didn't see any obvious signs of the solder on the traces, which would be not hard to do because of the way this board was designed.
