should OSTs in motherboard VRM sections always be replaced?
  • mrmazda
    MrMazda
    • Sep 2013
    • 115
    My ECS P965T-A has spent nearly the whole time since I bought it new over 6 years ago running OS/2. It's installed multiboot, so there is some running time in Linux and DOS. Quite some time ago already, maybe around 3 years, I replaced a very large number of 8mm caps on it, but not its 3 purple 10mmX25mm OST RLX 1500uf 16v. I no longer recall details, but suspect I had some bulgers and replaced everything of same specs with suitable low ESR replacements I had on hand at the time. As I use it constantly, I wanted it back in service without waiting on ordering what I didn't have. Doing what I did got it going.
    Since then I acquired some Rubycon MCZ 1500uF 16v 10mmX20mm from Topcat, so when it started fritzing today, and based on the OST reputation here, I decided to install them without even thinking about what other than dust accumulation and overheating could be wrong. On removal I checked and found all 3 OSTs measured above 1500uF, with highest ESR of the three .01. The Rubys I put in measured ESR as high as .02, and uF as low as 1472. The board still has some smaller OSTs (100uV 6.3v) and G-Luxons (470uF 16v & 100uF 16v). I put it back together with just the 3 new, but the corrupt video output was at least as bad, maybe worse. Turns out a near twin "new" PCIe X600 Radeon fixed it.
    These 3 OSTs seem to be far better than their reputation here. Should I commit them to the trash anyway? Save them for use in power supplies? Other?
  • c_hegge
    • Sep 2009
    • 5219
    Re: should OSTs in motherboard VRM sections always be replaced?
    Their ESR specifications make them unsuitable for use in PSUs. Those 3 caps are used on the VRM high side - one of the least stressful areas of a motherboard. OST can sometimes be OK if they are not stressed.
    • pc7fan
      • Aug 2013
      • 52
      Agreed with you c_hegge - I've seen OST go bad in PSU's, especially in the 5Vsb section. They really despise heat AFAIK and just fail most of time without any physical signs. They're just fine in low heat & stress applications, I actually reuse them in other projects I build (not critical) if they test good for ESR & capacitor in the first place and I don't have any problems.
        • 31072
        that's the ost weakness.
        get them hot and they will be bloated in a year or 2 worst case.
        keep them cool and you can get 20years from them - maybe more!!!
        • MicroSMD Lab
          MSI MS-16W1 no power, EC replaced by other.
          by MicroSMD Lab
          Hi, I'm working on a MSI laptop, Motherboard number MS-16W11, GF-65 Thin 10SDR-459US. Went to another shop because the screen was flickering, but it was working well on an external monitor. The LCD was ordered and the laptop was returned to the customer and it no longer worked. It was then sent to another tech (by the shop who ordered the LCD) and the EC (ENE KB9028Q) was replaced with a donor from another MSI board with different board number and no programming was done. It looks like work was done on PU6 (TPS51225) as well as one of the GPU mosfets was burnt (I removed all three GPU mosfets)....
          03-27-2025, 07:35 AM
        • thesame
          Asus FX505DD REV 2.0 no power after someone replaced the cmos battery with a screwdriver.
          by thesame
          I have a dead FX505D, motherboard FX505DD REV 2.0 , the owner replaced the cmos using a screwdriver and he touched something on the board, since then the laptop its not starting, i have managed to see that U8800 (BQ24780SRUYR) charging IC is getting hot under a thermal camera , i have desoldered it but the laptop still doesn't power on, i also have no voltage at power connector on the board. I also replaced the U8800 but still no power. What should i check next?
          04-22-2024, 01:21 AM
        • zlr8r
          HP Probook 640 G5 - replaced blown components, getting power led, fan full, 5-flashes on CAPS Lock and NUM lock, black screen
          by zlr8r
          Hey guys, bit stumped with this laptop after replacing 2 blown components i.e., MP86493, MP2979A.
          To begin with, this laptop was dead-dead.
          Now with replaced (visibly) blown components, i do get some progress; after connecting battery or main cable;
          • am getting white power led
          • 5-long-flashes on CAPS Lock and NUM lock
          • then, fan full speed
          • CPU heats up some (smaller die PCH, does not)
          • always constant black screen no matter what's tried
          • no USB recognition
          • no HDMI output
          this is as far as I can get with it and not sure where to inspect next ?
          I tried...
          03-27-2024, 03:13 PM
        • Loki_Fido
          Clean ME for VAIO please. Super I/O just got replaced
          by Loki_Fido
          Hi ya folks,
          Hope everyone's having a nice day.
          I recently replaced the super I/O chip and now I believe i need a clean ME for the system to come online. Cause i started the laptop and it did not start.
          Laptop details
          Sony VAIO
          Product name VJS111
          Model Number VJS111D12N
          Serial Number 7014633
          Motherboard markings
          FEILONG MB REV 1.03B
          UMT-KS 2V 94V-0 E49068 A7 1545 07-01
          Original bios file attached
          SUPER I/O chip model ITE IT8528VG
          Thanks a million in advance folks...
          05-11-2025, 11:40 PM
          Modification done to a EBC-A40L 5volts Battery Capacity Tester 40A for less noise when charging / discharging cycles
          When I first turned this battery testing machine the fan for the switching power supply was a little bit noisy but once I recapped the switching power supply board it quiet down considerably then I put a temperature controlled fan that does the mosfets control board was really noisy but now that it is cooled with temperature controlled fan that sensor was moved from the fan to the heat sink so now that the fan is controlled this way the fan runs according to the temperature of the heat sink
          This switching power supply was really fun to recap the quality of the board was very good...
          02-25-2024, 08:55 PM
