What brand are these caps ?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Here we have a vestel junker in today the inverter will try to start but will trigger a shutdown, I was able to by pass that shutdown and get the inverter to start but the lamps would flicker and burn dim, on close inspection the capacitors on the input are bulging and are probably failed, jus wandering what brand and series are they, thank you.
    • 31213
    Re: What brand are these caps ?
    just use something very good like panasonic FR
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Dont worry got some on order
      • brispuss
        • Dec 2012
        • 54
        • NZ
        Originally posted by ReeceyBurger123
        . . the capacitors on the input are bulging and are probably failed, jus wandering what brand and series are they, thank you.
        I'm wondering what brand these capacitors are also! Haven't found anything yet.
        Brown markings with voltage, capacitance, then series (doesn't look like date/lot code)?
        • selldoor
          Slow Learner
          • 7870
          is there meant to be a picture with that?
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Just some cheap junks that have failed, are the ones you have failed as well ?
            • brispuss
              • Dec 2012
              • 54
              • NZ
              Yes. See the first post in this topic by ReeceyBurger123.
              No. I don't have any of these capacitors. I was more curious as to the manufacturer of the capacitors shown in your photo.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Probably something cheap like lelon or taicon, inverter was recapped and is working fine.
                • eryjus
                  by eryjus
                  05-10-2023, 11:21 AM
                • Paxman_Swede
                  by Paxman_Swede
                  Hello!
                  01-14-2025, 09:51 AM
                • captain150
                  by captain150
                  03-16-2025, 07:34 PM
                • Foetuss
                  Gigabyte GA-6OXT :: caps question
                  by Foetuss
                  Good evening
                  I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                  Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                  But I was also suprised about the bigger boys, which are 330µF 25V.
                  Could it be they used 25V caps because they were cheaper / available at that time?...
                  02-11-2025, 12:22 PM
                  by momaka
                  03-12-2025, 03:42 PM
