Who else collects bad caps ?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    #41
    Re: Who else collects bad caps ?
    Originally posted by lti
    It looks like that first box contains mostly Samxon KM caps. Is there something wrong with that series?
    I have kept all the caps I have replaced that weren't leaking.
    The only really good reliable Samxon series that I trust are RS GD GC any others I have/heard of common failures.
    • lti
      • May 2011
      • 2547
      That's interesting. The only good series are the ones that are commonly used to repair motherboards and power supplies.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        #43
        Was samxon series do you trust/recommend ?
        • kasfamily
          • Aug 2014
          • 765
          • Russia
          #44
          Yes 47uF 400V of power supply settop boxes. All other bad cap of equipment that I repair -TV, monitors, receivers, fax machines, and various power supplies.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            #45
            Ohh wow I see now, so all them power supplies have the same defect with heat ?
            • kasfamily
              • Aug 2014
              • 765
              • Russia
              #46
              Yes, these power supplies are very strange, some overcook and burn, but many continue to operate normally.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                #47
                Strange do you install any fans to cool them after repairs ?
                • kasfamily
                  • Aug 2014
                  • 765
                  • Russia
                  #48
                  Power supplies in the box is donors for the repair of other. In the receiver, I put a different model power supply, as they are more reliable, which do not overheat.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    #49
                    Oh right good to here that you use a whole different psu
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      #50
                      Anyone els willing to share any photos of their collections ?
                      • Topcat
                        The Boss Stooge
                        • Oct 2003
                        • 16956
                        I had several 5 gallon buckets full. they started stinking up the shop, so I trashed them.
                        <--- Badcaps.net Founder
                        Badcaps.net Services:
                        Motherboard Repair Services
                        http://folding.stanford.edu/
                        Team : 49813
                        Join in!!
                        Team Stats
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          #52
                          That why I keep mine in a sealed bag becuase it makes the room smell like mould, and sniffing the bag closely it smells almost like fish.
                          • kasfamily
                            • Aug 2014
                            • 765
                            • Russia
                            #53
                            Those bad caps that emerged and smell bad, I throw in the trash immediately. In my Collections only very pleasant smelling instances.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              #54
                              Lol
                                by momaka
                                03-12-2025, 03:42 PM
                              • eryjus
                                by eryjus
                                05-10-2023, 11:21 AM
                              • Paxman_Swede
                                by Paxman_Swede
                                Hello!
                                01-14-2025, 09:51 AM
                              • captain150
                                by captain150
                                03-16-2025, 07:34 PM
                              • Foetuss
                                Gigabyte GA-6OXT :: caps question
                                by Foetuss
                                Good evening
                                I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                                Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                                But I was also suprised about the bigger boys, which are 330µF 25V.
                                Could it be they used 25V caps because they were cheaper / available at that time?...
                                02-11-2025, 12:22 PM
