Who else collects bad caps ?
https://www.facebook.com/Telford-Tel...7894576335359/ -
https://www.facebook.com/Telford-Tel...7894576335359/Comment
Re: Who else collects bad caps ?
i had some asshole send the police to a place i worked with once.
guy had brung a tv in dead, the fuse was blown and psu bad.
he refused the repair quote and took it away.
now someone had left the blown fuse out,
he took it someplace else - or opened it, and noticed the fuse missing and called the police!!!
when the police came to the repair shop they looked soo sheepish over it!
we being helpfull people gave them a few new fuses and told them to get lost!!
hopefully the bastard who called the police put a new fuse in and plugged it in again!!!
there is a reason we leave them out, it's to avoid liability.Last edited by stj; 11-05-2014, 11:28 AM.Comment
there is a reason we leave them out, it's to avoid liability.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
if they had pushed the point, i suppose we could have blown a new fuse for them!Comment
Thats mental I bet the police found it very foolish as well but had to follow orders, probably would have blown as soon as he installed it hope it did.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Last edited by ReeceyBurger123; 11-06-2014, 04:10 PM.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
Also weird question but how come the second box the majority of the caps are them 47uf 400v capxons that look like the caps that from them set top box power supplies that you posted in "the hall of shame" are they from them set top boxes ?Last edited by ReeceyBurger123; 11-06-2014, 04:10 PM.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
They often go bad without visible signs. Probably around 95% of Samxon KM's I have replaced have not been showing any visible signs of failure, but measured way off.
Samxon GS is another series that is bad, I can't remember seeing a single good GS-series cap, they have always measured very high ESR or open.
And they never show any visible signs.
Now, GS series should never even be used on a power supply, as it is a 85C general purpose series, but they are still very common. Especially on set-top box power supplies.
But KM series is actually listed for power supply use on the datasheet, yet they still are very common to see bad, so that is certainly an bad series...Comment
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by eryjusHello,
by Paxman_SwedeHello!
I have studied the board and...-
by captain150I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...-
by FoetussGood evening
I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
But I was also suprised about the bigger boys, which are 330µF 25V.
Could it be they used 25V caps because they were cheaper / available at that time?...-
- Loading...
