Are all of these caps bad?
  • Agent13
    • Oct 2014
    • 5
    It appears the smaller caps have a leak in the top?
    What is going on with the ooze on the bottom of the larger caps?
    Thanks!!
    • 31025
    Re: Are all of these caps bad?
    sometimes the pressure forces out through the top stamp, other times it gets between the wire and the rubber bung - whatever gives first.
    i can say with pana FC's if you do overstress one, the bung will leak long before the top domes or bursts.
    btw, did you intend to attache foto's ? your wording made me think you did.
    • Jooo
      • Oct 2011
      • 222
      • Finland
      It is glue
      • c_hegge
        • Sep 2009
        • 5219
        Yup. I'm pretty sure it's just glue.
        Also, don't use photobucket or other 3rd party image hosting here. We prefer it if images are attached to your post locally.
          • 31025
          yay, i see foto's this time.
          yep, that's old glue - probably evostik or some variant.
          • Fast Alpha
            • Feb 2013
            • 245
            • United Kingdom
            Why do they do that on them for ?
            http://www.hse.gov.uk/pubns/indg305.pdf
              • 31025
              probably to hold them down before the solder-wave machine does it's thing.
              • delaware74b
                • Apr 2009
                • 628
                That glue was a tan color when new. When it turn brown from heat, it gets conductive and
                Don't ask me how I know conductive glue in a power supply
                Stupidity should be a crime, especially for drivers. I have NO patience for them.
                • CapSwapper
                  • Feb 2014
                  • 69
                  how old is the device? if 5 years or older I always unsolder at least one to see what the reading is. I found a lot of junk caps that way. caps can go bad without any visible defects
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    Judging by the color of those caps and the board layout, it's at least 15 years old, if not more.
                    A working TV? How boring!
                    • Agent13
                      • Oct 2014
                      • 5
                      29 years old
                      Thanks for the responses all. I'll start to desolder them and take a look at their readings.
                        by momaka
                        03-12-2025, 03:42 PM
                      • eryjus
                        by eryjus
                        05-10-2023, 11:21 AM
                      • Paxman_Swede
                        by Paxman_Swede
                        Hello!
                        01-14-2025, 09:51 AM
                      • captain150
                        by captain150
                        03-16-2025, 07:34 PM
                      • Foetuss
                        Gigabyte GA-6OXT :: caps question
                        by Foetuss
                        Good evening
                        I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                        Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                        But I was also suprised about the bigger boys, which are 330µF 25V.
                        Could it be they used 25V caps because they were cheaper / available at that time?...
                        02-11-2025, 12:22 PM
