Nichicon 6.3v 1000uF HN vs HZ
  • Almighty1
    • Apr 2014
    • 222
    I was wondering for recapping a ASUS P4C800-E Deluxe Motherboard for the 20 x Rubycon YXG 6.3v 1000uF caps, is there going to be a big difference in performance, stability between the Nichicon HN and HZ series as I noticed they are both listed as Ultra Low ESR by vendors but I couldn't tell what the actual differences there are, is the HN already good enough or would the HZ be overkill? Which one is at least as good as the Rubycon YXG?
  • mockingbird
    • Dec 2008
    • 5488
    Re: Nichicon 6.3v 1000uF HN vs HZ
    No, not in this application.
    If the originals were only YXG, then you should be able to use even Nichicon PW class...
    The difference between 6.3V 1000uF in those two series are:
    (8x15mm)
    HZ = 0.014 ESR 2210 Ripple
    HN = 0.020 ESR 1700 Ripple
    Take care not to buy from China. You'll most certainly get fakes off eBay.
    • c_hegge
      • Sep 2009
      • 5219
      Almighty1: Those caps are for filtering the more 'minor' voltages, such as those for the USB ports and PCI slots. HN and HZ are both miles 'better' in terms of specs than Ruby YXG, but since they are not on the CPU VRM, it's unlikely to make much of a difference (unless you want to overclock the RAM, in which case you could just replace the few on the RAM VRM)
      Mockingbird: Nichicon PW is not a suitable replacement for Ruby YXG. They are on par spec wise with Nichicon HE and Chemi-con KY, and thus PW would be a downgrade.
      • Almighty1
        • Apr 2014
        • 222
        Thanks guys, what is the ripple and ESR rating of the Rubycon YXG's anyways? I can get the HZ at the same price as the HN except it will take an addition week because they need to order it from their distributor. With built-in on-board NIC's such as the Intel Pro1000/CT that goes through the CSA, does it actually go through capacitors at all? Forgot to ask but does Panasonic have anything comparable to the Nichicon HN and HZ?
        • mockingbird
          • Dec 2008
          • 5488
          Thank you.
          I stand corrected.
          • Almighty1
            • Apr 2014
            • 222
            Just looked at the specs of all three:
            Original:
            Rubycon YXG 87mOhm 504mA 4000hrs 8x17.5mm
            Replacement candidates:
            Nichicon HN 20mOhm 1700mA 2000hrs 8x15mm
            Nichicon HZ 14mOhm 2210mA 2000hrs 8x15mm
            Seems like the Nichicon's just have a shorter lifetime at 105C.
            c_hegge, since the ESR is lower on the HN than the YXG's by over 400%, wouldn't the HN already do well for overclocking the RAM which are just DDR PC-3200 memory?
            • c_hegge
              • Sep 2009
              • 5219
              Yes. Either would be a major upgrade in terms of specs.
              • Almighty1
                • Apr 2014
                • 222
                Just as I thought, thanks as always c_hegge!
                • DrewPhillips
                  Capacitor Diarrhea - Nichicon PL Series
                  by DrewPhillips
                  Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
                  The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
                  03-02-2025, 10:18 PM
                • omon
                  Please help find a replacement for Rubycon A0817 6.3V 1000uF 105C MBZ
                  by omon
                  I was hoping to get some help in identifying a replacement capacitor for a PET Rubycon A0817 6.3V 1000uF rated for 105C temp, MBZ series.
                  This is to replace one bad capacitor on a DELL 530 motherboard DG33M03 (manufactured by Foxconn, DELL part # FM586).
                  I'm attaching the pictures of the bad cap.
                  Thank you so much!...
                  04-28-2021, 05:43 AM
                • nick3092
                  Mid/late 80's Nichicon Yellow Caps
                  by nick3092
                  I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
                  08-28-2022, 03:56 PM
                • withalligators
                  Looking for best replacements for Capxons, but can't find data sheets
                  by withalligators
                  Recapping the power supply board for a Samsung 305T monitor, everything is Capxon except 2 Rubycons. I can't find data sheets matching these online, so don't know what ripple numbers, impedence, etc, to look for. There are a few different looking GL series data sheet PDFs, but the listing that matches the capacitance and voltage is a much bigger case size. I've narrowed down selections with lead spacing and case diameter, and what's in stock at Digi-key
                  1 x Capxon 1000uf35v GL C720(is this a part number or batch number, can't find it anywhere) 105c
                  1 x Capxon 1000uf35v...
                  03-25-2022, 02:30 PM
                • Per Hansson
                  Repair of Sign WiFi Smart Plug PCB: SA-P302A v1.2 due to bad caps - with schematic
                  by Per Hansson
                  I have repaired a Sign WiFi Smart Plug with model number: SNSM-WASINGLE sold by Spares Nordic AB in Sweden.
                  The fault condition was that the device gave no signs of life: pressing the push button did not cycle the internal relay and the blue LED did not come on and it was not seen on the WiFi network.
                  The fault was very simple, capacitor C3 on the PCB with writing "KSJ" and "LOWESR" had literally blown its top off, after replacing it the device works fine again!
                  As I find linear high voltage regulator designs interesting I drew up the attached schematic...
                  12-23-2023, 06:20 AM
