Capactior Qustions help please
  • TKF
    • Oct 2013
    • 31
    • US
    I've got 2 bulging capacitors on a Samsung power board they are Capxon I've picked a couple of Panasonic ones to replace them could anyone advise if the ones I picked are suitable replacements or any suggestions
    Bad ones capxon
    1000uf 10v,10x16size1040ripple,0.076inpedance
    470uf 25v,10x16size1200ripple,0.076inpedance
    Replace with Panasonic
    1000uf 10v,10x16size,1.790ripple,0.026inpedance
    470uf 10v,10x16size,1.790ripple,0.026inpedance
    Got from these data sheets
    http://www.paullinebarger.net/DS/Capxon/
    http://www.paullinebarger.net/DS/Panasonic/
    Thanks for any help
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    Re: Capactior Qustions help please
    The 470uf should be rated at 25v as the original is, not 10v.
    I don't think the ripple numbers are represented in your post correctly but I'm not gonna dl the pdf's to check them.
    • TKF
      • Oct 2013
      • 31
      • US
      SteveNielsen Your right I mistyped it should read 470uf 25v and the ripple should read 1790 I copied those specs from the data sheets would they work ok for replacements
      Thanks for the help
        Higher ripple rating is OK/Better.
        • TKF
          • Oct 2013
          • 31
          • US
          Thanks for the help Steve ,Bud got them ordered today
          • TKF
            • Oct 2013
            • 31
            • US
            I replaced the 2 caps but didn't help I'm going to replace the all of the caps which I should have done to start with. I can't find some of the caps in the Panasonic FM or FR series but there's some in the FC series from the data sheets I can't see a lot of differences other then a wider Temp range and Impedance is a little lower for the FM an FR
            My question is would the FC work OK, or is there better choices.
            Thanks for any help
            • Almighty1
              • Apr 2014
              • 222
              From what I have seen looking at the datasheets for the FC, FM, and FR is that the FC just has a shorter endurance life compared to the FM and FR.
              • TKF
                • Oct 2013
                • 31
                • US
                Thanks for the help Almighty1 I just wanted to make sure that the FC series caps are suitable for Power Boards I have already installed 2 FM caps on this board trying to stay with Panasonic the closest matches I could find to the FM and FR series was the FCs.
                Thanks again
