Nvidia 790i Ultra Bad Caps Causing Problems?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Nvidia 790i Ultra Bad Caps Causing Problems?
    Did you end up replacing them, if so did it fix the problem ?
    • mikay786
      • Aug 2014
      • 765
      Hi, Yes replaced them yesterday and have not had a crash since.
      Big thanks to all you guys for the advice and help, that's two things fixed now thanks to this board!
      • mikay786
        • Aug 2014
        • 765
        http://uk.farnell.com/jsp/search/pro...sp?sku=1144672
        RUBYCON - 6.3ZL1500MEFC10X20 - CAP, ALU ELEC, 1500UF, 6.3V, RAD (ZL Series)
        guys would the above be suitable as a replacement to the Sanyos?
        Ive got another board with the exact same caps leaking on them cant be arsed waiting 2 weeks for the MCZ from eBay China, these are local to me so can pick up. Well anything from Farnell will do as is local to me.
        • RJARRRPCGP
          • Jul 2004
          • 6304
          Originally posted by c_hegge
          I would not recommend increasing the voltage unless recapping doesn't help. I think you're board only plays up because it's an ASUS and probably has a cheapped out VRM.
          I didn't mean that. I assume that the board is to be recapped first before making voltage adjustments.
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • RJARRRPCGP
            • Jul 2004
            • 6304
            Originally posted by momaka
            Also, higher RAM voltage means higher thermal dissipation for the chips on the RAM, hence shorter lifespan for the RAM - especially for the cheaper brands.
            1.9 V is unlikely to damage DDR 2.
            High failure rates are mostly with 2.0+ VDIMM and with DDR 2 Micron D9s.
            Arc A770 16 GB
            • mikay786
              • Aug 2014
              • 765
              As above will these caps do?
              • c_hegge
                • Sep 2009
                • 5219
                Rubycon ZL? No. They are too high ESR. Farnell do not have anything suitable for this application (although a panny FM might just be close enough if you can squeeze a physically larger cap in). Use https://www.badcaps.net/store/produc...products_id=39 from badcaps.net
                • mikay786
                  • Aug 2014
                  • 765
                  Anything in the UK you can recommend?
                  RS Online has a UK branch too.
                  http://m.rs-online.com/h5/mobile/uk/...um-capacitors/
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    #29
                    Good to here, enjoy your system
                    • c_hegge
                      • Sep 2009
                      • 5219
                      The appropriate capacitor series are all discontinued now. RS and element14 will have all sold out long ago. badcaps.net is about the only one that still has stock of them, as Topcat did a massive bulk order shortly before they were discontinued (and yes, badcpas.net does ship to the UK).
                      HOWEVER
                      There are a few series which are not ideal replacements but might just be close enough. Panasonic FM series is probably the closest in terms of electrical specifications, but, like the Ruby ZL you were considering earlier, it is physically a few mm larger in diameter, so you may have a hard time squeezing some of them in.
                      Since the caps in question do appear to be used for VRM filtering, you could probably poly-mod the board using lower capacitance (like 820uF) solid caps such as Nichicon FPCAP L8, which are the correct diameter. I've had pretty good luck poly modding motherboards in the past like this, but be warned that it is experimental and I don't by any means guarantee that it will work.
                      • mikay786
                        • Aug 2014
                        • 765
                        Cheers, ordered 15 from badcaps last night, thought id order a few extra as this seems like a common problem with these boards.
                        • hsdb
                          Purchased a 790i Ultra, the seller replaced 4 caps with new ones and possibly higher values and now the board won't fit long GPUs anymore in slot one, original values unknown. Can anyone help identifying voltage and capacitance of the four highlighted in red below?
                          The caps in question are:
                          C4J12, C4J13, C5J3 C5K2 located immediately behind the floppy connector.
                          Thanks in advance.
                          • diabedon
                            • Apr 2024
                            • ruj
                            #33
                            I wouldn't really recommend MCZ as they have unstable electrolyte like KZG and typically don't last very long. Some short out without signs of damage, but I haven't experienced that, just very vivid deaths.
                              • 31209
                              MBZ / MCZ have not been made for many years now,
                              any for sale are fake or ancient
                                master hoarder
                                • May 2008
                                • 12175
                                • Bulgaria
                                #35
                                Most MCZ (and MFZ) I found on eBay were genuine, but rather old stock.
                                The 6.3V ones may indeed be a bit "unstable", especially used ones pulled from old boards, and also if they have sat unused for very long... at least that's my personal experience.
                                MBZ, on the other hand, seem to hold up OK. Haven't had issues with any yet.
                                That said, Panasonic FR, FM, and FS along with UCC KZH and KZM and Nichicon NV/HW can often be "good enough" for most motherboard use cases.
                                  LG Gram Ultra-Lightweight Notebook Specification for Upgrade or Repair
                                  This specification for the LG Gram Ultra-Lightweight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Lightweight boardview and Ultra-Lightweight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  09-07-2024, 03:40 AM
                                  LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                                  This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                                  This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  09-06-2024, 09:10 PM
