From my 3D printer, is this a capacitor?
  • CyberCiphers
    Random
    • Jul 2025
    • 6
    Hey there,
    I'm largely still a student and unsure about identifying components like this, anyone have any idea what this is and if I have another one, fairly straight forward to swap out?
    From my Bambu Labs AMS - had connected the wiring incorrectly .. Whoops!
    Cheers!
ID:	3682954 Click image for larger version
ID:	3682953 Click image for larger version
  • PeteS in CA
    • Aug 2005
    • 3583
    • USA, Unsure of Planet
    Based on the silkscreen reference designator and it having three leads, I think it might have been a TVS diode.
    PeteS in CA
    • CapLeaker
      Leaking Member
      • 8352
      Whatever ED1 is for a TVS look at ED2. They are probably the same.
        • 31289
        SOT23 package.
        could be:
        NDS7002A
        V-MOS, 60V, 0.28A, <2Ω(0.5A) N-type Mosfet
        • redwire
          • 3912
          Board marking "485" so I would say it is a dual TVS for protecting the RS-485 port. ED1 likely same as ED2 "712"
          Bourns SM712 or Littelfuse SM712 etc.
          If this is the port you wired wrong.
          • MORETTIGIAN
            Capacitor detached from PCB – RTX 2070 Super Founders Edition
            by MORETTIGIAN
            Title:
            Description:
            During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
            I did not notice it detaching, so I am unsure of its original location on the PCB.
            Procedure performed:
            - Removed backplate
            - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
            - Reapplied thermal compound
            - Reassembled card
            Observed behavior after reassembly:
            - GPU powers on and operates normally under...
            09-18-2025, 12:14 PM
          • re-atari
            Anycubic Photon 5.5 3D printer 25Q32 flashrom dump needed
            by re-atari
            Hello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
            Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he...
            02-03-2025, 06:49 PM
          • Prolog
            RTX 3080 FE Identifying capacitor
            by Prolog
            Hi people, I hope this is the correct spot to post this, I'm new to the forum.
            I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
            I hope these photos make it clear which component I am referring to:
            (yes, the soldering is a bit botched from removing the blown one, I know)
            I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
            12-01-2024, 08:27 PM
          • Agent24
            Dick Smith Q-1760 linear power supply filter capacitor question
            by Agent24
            I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
            It has at least one problem.
            The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
            I have already ordered a replacement potentiometer, so that's not an issue.
            Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
            All are CapXon...
            10-21-2025, 05:39 PM
          • Curious808
            Brother HL-2140 laser printer: printer error (solved)
            by Curious808
            SOLVED. I removed the printer in settings, replugged and let it reinstall and it worked this time.
            Windows 10
            Attempt to print and immediately get a Windows pop-up saying "Error printing". The document appears in the printer queue window with Status "Error-printing".
            Turned off printer. Unplugged, waited, replugged. Ran the Windows troubleshooter. Removed and reinserted toner cartridge. Checked for paper jam. No printer error lights. Reinstalled driver. Restarted the Spooler service. Rebooted...
            06-22-2023, 11:11 PM
