LG TV horizontal lines
  • Kylebronson
    • Aug 2014
    • 10
    . On start up it has horizontal transparent lines (about 3inch thick) traveling up the screen. After about 20 min, the picture is perfect. I'm about to take the back cover off today...any guesses about what it could be? Bad cap? Power supply?
  • mmartell
    • Oct 2013
    • 3189
    Re: LG TV horizontal lines
    Operator error ? J/k...
    Pictures or video of the fault might go a long way. But hit the main board with some heat from a hair dryer at start up and see if you can make the problem disappear faster.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Mmartell Whats that about?
      Anyway further errors - it is the wrong section should be in Troubleshooting TVs and should have the make and model number in the title.
      Suggest you scrap this and start again then when your other thread is posted
      click on this thread in left hand column there is a red triangle with an exclamation mark in it - click it and ask a mod to remove it
      • mmartell
        • Oct 2013
        • 3189
        Twas a little humour since the OP was soliciting suggestions for an issue sans pictures or video or had yet to take the back off. No ill will intended, dad.
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
        • Ihandyrepair
          Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
          by Ihandyrepair
          Hi guys
          I just started fixing 4k TV few months ago. so I am still learning a lot
          I got this tv from friend complaint is ghosting or horizontal lines on image.
          never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
          then it started to show the ghosting white image.
          I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
          it has 3 thin small boards at the bottom of the...
          12-05-2022, 04:18 PM
        • ggil44
          Sony XBR-65X750D Horizontal lines bottom of screen
          by ggil44
          Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
          05-30-2023, 07:51 PM
        • noisykid
          Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
          by noisykid
          5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
          12-30-2024, 07:15 PM
        • x_orange90_x
          Samsung UN46C8000XFXZA Horizontal lines
          by x_orange90_x
          I just acquired this 3D LED yesterday and it has horizontal lines on a little more than half of the screen. When I first turn it on it has thin black lines going across that makes the image look serrated, and then shortly after patterns of thicker red lines fade in. If I turn it off and right back on it will reset to just the black lines and the red will again fade onto the screen.
          I initially thought tab bonds, but flexing the bezel makes no difference, and the fact the image sort of resets after cycling power is different. I haven't opened it up yet to actually test applying...
          07-15-2023, 05:06 AM
